HP Printer Error 0X610000F6 also known as Carriage trouble Error arises very often in the HP Printers. When trouble happens in the printer due to paper cuts or due to any other reason, the printer stops running and it doesn't print any paper. check this method to resolve.
3 Methods to Resolve Error 0X610000F6:-
1. First, Switch the OFF and Switch the On your Printer.
2. Remove all the Paper stuff that is Blocked.
3. Check Whether the Printer Cartridges are properly attached or not and Remove any jammed papers.
WANT FULL SOLUTION CHECK HERE - Hp Printer Error 0x610000f6
If you want a perfect & right solution recommended by an expert. follow the blog steps which are mentioned.
Step one: Turn the printer off, and then turn it on
Step two: Print a self-test report
for more help visit https://cbrtechsolutions.net
SOURCE: I get this error message : General Printer Error
Generally, this is Hardware Failure Error on HP Printers. You may try few steps before considering it is Hardware Failure.
If you still get this error,
Remove the Cartridges and Printhead
Printheads are that hold the cartridge and it has a latch on right side
to loose to remove the Printhead, if you dont find a latch, your
printer does not has Printhead. Generally, Printers with only 2
cartridges do not have Printheads and any printer beyond this with 4,5
or 6 cartridges have printheads. Sometimes the cartridges are on left
side or printer and Printheads inside the printer after you open front
access door or you will find cartridges and printhead both inside the
printer if you open the front access door )
Clean
the contacts ( Electrical or Golden contacts ) using lint free cloth. (
Cloth damped with few drops of water, squeezed properly )
Put the Printhead and Cartridges back and Turn off the printer and turn on.
If you have completed all the steps listed above and are still experiencing a problem, Service the product as it needs repair.
If your printer is In-Warranty, Contact HP Tech support - 1800-474-6838 and they should be able to replace it without charges.
Regards,
Ron,
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
SOURCE: Printer won't print. General Printer beware spam number 1*800*532*4187
This Error code means unit has a carriage jam
Follow the link below to resolve the issue :
h10025.www1.hp.com/ewfrf/wc/document
SOURCE: my printer will not print.
Hi there, regarding with the problem that you have..the error message that you are encountering with that machine is something about to work on with the printhead..because the printhead is the one causing the problem why is that the error message keeps on popping up, i believed that the printer model that you have is already out of warranty..the printhead is not replaceable if the printer is out of warranty.. well in that case, quite frankly the printer is already faulty.
you can definitely call HP by dialing this number 1-800-474-6836 and let them see what they can do in their end..
Thanks!
