Washing Machines Logo
Posted on Jan 01, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F2 code - Washing Machines
Anonymous
Level 3:
  • Master 4,323 Answers
  • Posted on Jan 01, 2011
Anonymous
Master
Level 3:
Answers
4323
Questions
0
Helped
1252152
Points
12716
Hi
Error F02 appears after 8mins of SUDs error. Error F02 means Long drain, means washer is taking longer time than normal to drain. Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the SUD error will be displayed, and then 4 minutes later the F02 error code will be displayed.
? Check the drain hose and make sure it is not plugged or kinked.
? Check the electrical connections at the pump and make sure the pump is running.
? Check the drain pump filter for foreign objects.
? If the above does not correct the problem, replace the pump.
There are 3 small 9/32 hex head screws that hold the front panel on. Unscrew the 3 hex head screws (9/32 socket or nut driver size), now remove the front kick panel. Unscrew the white drain cap -WARNING-- lots of water will drain out when you loosen the white cap. Once all the water is out, remove and take out the filter trap.
Hope this helps... Please post back for more information
Daniel
1helpful
GE TrueTmp Oven. What is error code F2? The oven was off and wouldn't stop heating.
Runaway temperature over 590'F!
How to Fix GE Oven Error Code F2
D3 Appliance https://d3appliance.com > News and Tips
Dec 6, 2021 - A GE oven error code F2 occurs when the oven temperature is too high. Follow our comprehensive guide to diagnose and fix the issue.
My General Electric Oven Is Displaying The F2 Error ??
Express Appliance Repair Winnipeg https://www.expressrepairwinnipeg.ca > general-electri...
If any wires are exposed or damaged then your temperature sensor is misreading your oven's heat which causes the F2 error code. If you have found any damaged or ...
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: 62px;"> Rating: 4.5 · ‎950 reviews
Missing: 326B1230P001 ‎' Show results with: 326B1230P001
How to Fix a GE Oven Showing Error F2
Hunker https://www.hunker.com > ... > Interior Home Repair
If you have a GE oven, the error code F2 on the oven means that the temperature sensor has detected a temperature in excess of the preset threshold.
Nov 25, 2023 • Ovens
Sharp AR-M316 photocopier. f2-02 error on it. How can I clear f2-02 error on this Sharp photocopier please?
Sharp ARM316 - Error Code: F2-02
PrintCopy .info https://printcopy.info > model=ARM316 > code=F2-02
Code: F2-02; Description: Toner supply failure. The value judged from the actual toner supply hysteresis differs greatly from the toner sensor value.
Missing: photocopier. ‎' Must include: photocopier.
How do i clear error F2-70 on sharp AR-5623N copier machine?
http://printcopy.info/?l=en&mod=erc&brand=Sharp&model=AR5623N&code=F2%2070
Sharp AR5623N Error Codes
Sharp AR5623N Error Codes Code: All codes CH Blink CH ON E7 01 E7 02 E7 06 E7 10 E7 11 E7 16 F2 40 F2 64 F2 70 F2 74 H3 00 H3 01 H4 00 H5 01 L1 00 L3 00 L4 01 L4 31 L4 32 L6 10 U2 04 U2 11 U2 12
Code
F2 70
Description
•Improper cartridge (Destination error, life cycle error) •Identific t ion error •Model error •Type error •Destination error •Data abnormality •Misc error Detail •The destination of the machine differs from that of the CRUM. •The trade mark code of the CRUM differs. •The company code of the CRUM differs. •The boot program model code does not coincide with the CRUM model code. •When the CRUM type is other than genuine/ conversion/production rotation. •The machine destination differs from the CRUM destination.
Causes
CRUM chip defect Improper toner cartridge.
Remedy
Replace the toner cartridge.
2helpful
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
61helpful
4answers
9helpful
4answers
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
4helpful
Error code F2-04 and E7-10 on AR-168D
F2-04 is an improper cartridge code and the E7-10 is a shading/lamp brightness issue. I would say the F2-04 is causing both coded, Change the toner cartridge. I have seen those chips on the back of the cartridges cause weird problems. That or the developer unit has failed.
I strongly suspest that once you resolve the F2 issue the E7 will simply go away.
Top Washing Machines Experts
AskDyson
AskDyson
ADMIN Andrew
ADMIN Andrew
