Samsung SlimFit TX-T2782 HDTV Logo
Anonymous Posted on Jan 01, 2011
How to program with cable using remote - Samsung SlimFit TX-T2782 HDTV
Level 3:
Top Expert:
  • Samsung Master 76,851 Answers
  • Posted on Jan 02, 2011
Samsung Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
15380470
Points
237768
Hello
1 Find and disconnect the cable that is connected to the
ANT IN terminal on your cable box.
? This terminal might be labeled "ANT IN", "VHF IN" or
simply, "IN".
2 Connect this cable to a two-way splitter.
3 Connect an Antenna cable between an OUT terminal on
the splitter and the IN terminal on the cable box.
4 Connect an Antenna cable between the ANT OUT terminal
on the cable box and the B-IN terminal on the RF(A/B)
switch.
5 Connect another cable between the other OUT terminal on
the splitter and the A-IN terminal on the RF (A/B) switch.
6 Connect the last Antenna cable between the OUT terminal
on the RF (A/B) switch and the ANT IN (AIR/CABLE)
terminal on the back of the TV.
After you have made this connection, set the A/B switch to the
"A" position for normal viewing. Set the A/B switch to the "B"
position to view scrambled channels. (When you set the A/B
switch to "B", you will need to tune your TV to the cable box's
output channel, which is usually channel 3 or 4.)
OK
  • The Knight
    The Knight Jan 02, 2011
    To assaign the cable by remote control do the following
    When the TV is initially powered on, basic settings proceed automatically and
    subsequently:
    1 Press the POWER button on the remote control.
    The message Start Plug
Tv won't turn on
Are you using a remote, or try to turn on manually. If your remote does not work, it needs to be programed to your t.v. And all remotes and t.v.s have different codes. Sometimes your cable provider will help you program your remote, or reset your cable box. My remote for my cable was not programmed, so I had to read the instructions myself to get the remote to work with the cable box channels.
I have a Trutech PLV1615T TV and a RCA RCR311 Universal Remote that I lost the info for. How can I get them to talk to each other....Thanks, Tom
RCA Universal Remote Control Programming Codes Programming Your Universal Remote.The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes: y TV-000 y VCR-000 y Cable Box-000 y AUX is programmed with VCR code 037For brands that require programming, there are two ways to program: Using Code Lists or CodeSearch. Use Code Search if the code lists are not available or if the codes from the lists do notoperate a device.Programming a Device using Code Search:1. Manually turn ON your device (TV, VCR, Cable Box)2. Press and "HOLD" CODE SEARCH3. Press and release the device button you want to set up (TV, VCR, Cable Box) However,if you are using AUX for a device, press and release AUX first and then the devicebutton for the type of device to be programmed (TV, VCR, or Cable). The selecteddevice button will flash once.4. Release CODE SEARCH.5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100times at a rate of once per second).6. Once the device turns off, press and release ENTER.7. With the device on, press any other button. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-6...Hope this helps! Parsos215
3helpful
2answers
Need directions 4 rca rcu 800b [rcu800-or rcu403 to program code
RCA TV Codes: 000,006,011,019,027,034,038,044, 046,088
RCA Cable Box Codes: 000,027
Special Notes:
RCA, GE and Proscan Brand Devices:
Many of these devices (TV's and VCR's) will not need to be programmed. In the event that programming is required, the code search method is suggested.
  • TV-000
  • VCR-000
  • Cable Box-000
  • AUX is programmed with VCR code 037
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
  3. Press and release the device button you want to set up (TV, VCR, Cable Box) However, if you are using AUX for a device, press and release AUX first and then the device button for the type of device to be programmed (TV, VCR, or Cable). The selected device button will flash once.
  5. Press OFF/ON repeatedly until the device turns off (you may have to press up to 100 times at a rate of once per second).
Programming a device using the Code Lists:
  1. Find codes for each device and brand below.
  2. Press and "HOLD" CODE SEARCH.
  3. Press and release the TV, VCR or Cable button you want to set up. If programming AUX for a device, press and release AUX first and then the device to be programmed (TV, VCR or Cable). When the selected device button flashes proceed to the next step.
  4. Enter the three digit code from the TV, VCR or Cable Box code lists.
  5. Release CODE SEARCH.
  6. With the device on, press another button, for example CHANNEL UP. If the device responds, no further programming is required. If the device does not respond, repeat steps 1-5 using another code number from the lists.
1helpful
Need to program a new remote for RCA TV
  • TV-000
  • VCR-000
  • Cable Box-000
For more info, copy and paste this link in your address bar so you can get codes for you remote:
http://www.thompsontv.com/rcarc.html
3helpful
Programming Cox Cable Box Remote to Vizio TV
using a cox cable remote. cant program to work cable and tv functions at the same time. please help?
1helpful
Volume control
We forgot the very last step in programming. I tried programming one more time today and it worked so now everything is working correctly!!
7helpful
3answers
RCA Universal Remote set to my Emerson TV
  • TV-000
  • VCR-000
  • Cable Box-000
Emerson CODES 011,026,027,028,029,030 031,032,037,042,053,064 065,067,075,076,079
Universal remote
Codes for Samsung (one of them should work on your RCA remote)
006,011,014,015,019,027,036,037,077
  • TV-000
  • VCR-000
  • Cable Box-000
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
