I have the same problem as jknight858. gas ignitor keeps on clicking when all four burners knobs are in off position. The unit started clicking without anyone in the room. Solved the problem by unplugging the unit. \
Unit is not wet and is suppose to be sealed so wetness cannot get inside the unit.
What is the solution to fix?
norman@pacificsupplies.com
Norman Dole 714 321-3653 cell
Have you tried to just move the knob away from the 'Start" position. this sounds like the ignitor is still engaged. Aside from that, I'm not sure of a solution.
Just solved this on the Kenmore model 911.33389 (same unit). Ignitors started with no one touching the cooktop. It has had a history of doing this and, this time, sparks were visible under the knob. Disassembled cooktop (don't forget to unplug and shut off the gas!). Performed "smell test" for burned electronics. Found smell in #3 ignitor switch. Disassembled and found worn, burned, and fried. Parts list was inside unit but had a typo for the "ignitor switch". Showed WB18T10240. Ordered that only to discover it was the transformer to ignitor wire harness set (no photo on website!). Wrong part... ugh! Dug deeper for the correct part #. It was WB18T10239 but it has been replaced with WB18T10344. Noted on some website that someone installed one and then the ignitor was NOT synchronized. Turns out, you can install WB18T10344 about three different ways. Mine was 22 degrees off vertical (different than original) and now my unit works perfectly! Also, install the new switch harness (if that's what you do) starting from the left front valve then clockwise. The original unit installed from the right front valve, then clockwise. Hope this helps.
THAT IS THE IGNITOR FOR THE GAS. TURN THE KNOB JUST BEYOND THE START POSITION AND IT SHOULD STOP. IF NOT UNPLUG THE STOVE AND FIND THE IGNITOR ON THE BURNER HEAD AND CLEAN IT WITH A SOFT TOOTHBRUSH. PLUG THE STOVE IN AND IT SHOULD STOP CLICKING
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat.The surface of the board was charred beyond repair. To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs.If it ignites, then it is the control knob electronics.If it doesn’t, then there is something wrong with the igniter. Note: The 2-zone Wok Burner had a different control knob that the other burners. To open the cook top, do NOT loosen any of the Phillips screws on the sides.Here are the instructions from the user manual: Disassembly Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs. In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports. Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob. Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals. To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
If you have recently cleaned unit and got moisture behind knobs, this may stop when the spark switches dry out. If not you will need to replace spark switches behind the knobs.
