SOURCE: Motorola H350 doesn't connect...
The issue is with the PS3s compatibility with the H350. Sony should be fixing some of the issues with an update, but from what i've checked online, the H350 is a problematic headset. i just got one as well, and have connection issues with it online.
SOURCE: PS3 internet connection problem
if wireless you have got to go to the router and un plug the ethernet cables and the power cable then plug them back in then it works i have had this problem
SOURCE: Im trying to set up
passkeys should be entered for both devices.
like when you are trying to paired your phone with you friend's
it would then asked to type in a passkey, you can type in any passkey you like but it should be same combination with your friend's. (so you can use 1234 punch in on yours and your friends need to use 1234 code punch in his phone, so both bluetooth device will be paired successfully).
SOURCE: ps3 system update data corrupted
Hook up the external to your USB port and copy everything over. I had to do that when I installed a larger hard drive in my PS3
SOURCE: Passkey for bluetooth?
most bluetooth earpiece pass keys are 0000 or 000000. Hold the device power button down until the lights flash two colors, then locate device with the blackberry. Enter either of the two codes and see which works. Normally you can not change the code on the earpiece, but you can on the phones.
