Bosch 24 in. SHX99A15UC Stainless Steel Dishwasher Logo
A
Anonymous Posted on Jan 10, 2011
Error code E24 on a new Bosch dishwasher that was just installed. This is the first time I tried to run the dishwasher after installation.
3 Related Answers
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Mar 31, 2010
SOURCE: bosch dishwasher lfestyle automatic runs for 1 min
e24 means the water supply isn't getting in
www.homeclick.com/PE-Links/Bosch/Bosch-SHE68E15UC-manual.pdf
This manual has troubleshooting that you can use for yours too.
Anonymous
  • 608 Answers
  • Posted on Dec 09, 2010
SOURCE: I have a bosch dishwasher
Error code 24 for a bosch dishwasher is either a bad pump or a plugged drain or airgap. This is where your washer connects to the plumbing system. If you are under warranty have it fixed if not I would start by seeing if your system and make sure it isn't plugged first. After that it could be the pump has failed.
Hope this helps
Anonymous
  • 4323 Answers
  • Posted on Jun 20, 2011
SOURCE: My Bosch Eco Sense dishwasher shows error code
Hi
E24 error indicates draining failure and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Hope this helps... Please post back for any further assistance.
Daniel
Top Bosch Dishwashers Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
