SOURCE: sending fax
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
SOURCE: Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
SOURCE: need to reset key operator code on Sharp AR-287
Make sure the copier is in "copy" mode.
To get into service mode press the following keys one after the other "P" key - "interupt" key - "clear" key - "interupt" key (do not play around with setting in service mode as this can render your copier useless)
enter 22 and press "start" enter "7" and press start. This should display the admin code.
Restart the copier and you should be good to go.
SOURCE: Reset Error Code F6-10 for Sharp AR-M277
This code is communication problem between the machine and fax board... The battery on the fax board will need to be replaced.
Usually turning off your machine will make this go away, for awhile.
Sometimes preventing your machine from going into Sleep Mode also helps.
The Fax Battery is much like the CMOS battery in a computer.
A large round thin battery, (much like a watch battery)
To replace this, the fax board has to be removed, The battery is
Soldered to the Board, you have to unsolder the battery, then solder
the new battery to the fax board, then reinstall fax board, then set
jumpers on fax board. Turn machine on, do some simulation settings, turn machine
off, remove jumper from fax board. Then restart, hopefully you will not
have to reset the county code.
Unless your experienced with this, do yourself a favor and call a tech..
