RCA RCR311B Remote Control Logo
Posted on Jul 13, 2008
Remote what is the steps in programing remote control
  • Anonymous Jul 15, 2008
    Have the codes but NO code search button. What's up. What do I do? RCA universal remote RCR311W
Anonymous
Level 1:
Problem Solver:
  • Contributor 8 Answers
  • Posted on Jul 17, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
8
Questions
0
Helped
2741
Points
26
Manual Code Search and Entry 1. Manually turn on the TV
2. Press and hold the TV button The illuminated ON•OFF key turns on and remains on.
3. While holding the component key down, press and hold the ON•OFF key. The illuminated ON•OFF key turns off.
4. After holding down both keys for three seconds, the illuminated ON•OFF key turns back on.
5. Release both keys. The illuminated ON•OFF key remains on. TIP: Throughout the programming of each key, be sure to keep the remote pointed at the IR sensor of the component you are currently programming the remote to control.
6. Press and release the ON•OFF key repeatedly until your component turns off. Each time you press the ON•OFF key, the illuminated ON•OFF key blinks, and the next
code in the list is sent. This process continues until all of the codes in the Code Lists have been searched. If your component turns off, you have found the correct code.
TIP: Because there are so many codes, you may have to press the ON•OFF key many times-possibly up to 200 times.
7. Once you have found the correct code, you must save the new code by pressing and releasing the STOP key. The illuminated ON•OFF key turns off. You must press the STOP key to save the code or the correct code will not be stored!
8. To confirm that the component key is programmed with the correct code for maximum functionality, test the component. Attempt to control a variety of the component's functions with the remote. If some of the features of your components do not work, try programming the remote with a different code in the list until you find the code that allows the remote to control the majority of your component's functions. Different codes can provide different levels of functionality
Viper 5904 viper delete codes
Keep in mind once you erase you current remotes NONE of them will work until you program/pair them back again with your alarm. The 2-way remotes are different to pair than the 1-way. Having said that it's pretty simple to delete/unpair the remotes. I'm gonna try to keep it as simple as I can.
The alarm has to be disarmed and NOT in valet mode.
Step 1 open door (keep door open thru entire operation)
Step 2 turn ignition to ON position (not accessory)
Step 3 within 10 seconds press program/control button on antenna twice (push and let go, push and let go. DO NOT HOLD)
Step 4 NOW press and hold program/control button again (DO NOT LET GO) you'll hear siren chirp
Step 5 while still holding program/control button press the LOCK button on your remote control the siren will chirp again confirming remotes have been successfully deleted/removed.
Step 6 let go of program/control button
Step 7 close ignition switch to finish everything you did. NOW you have to pair ALL your remotes back to the system.
Hope this helps.
Funny thing same thing happened to me with the car option 1 and car option 2 remote.
Hi my samsung remote is damaged.I have a one for all tv universal remote & have lost the instuctions to program the remote to the tv. I need the instructions program my one for all tv remote to my...
Hello
These are the programming proceedings for a one for all universal remote control.
[1] Turn on a desired device (e.g.,VCR or
DVD player) and, if applicable, insert
media (e.g., cassette or disc).
NOTE: Please read steps 2 through 4 completely
before proceeding.Highlight or write down the
codes and device you wish to program before
starting step 2.
[2] On the remote control,press a device key
once (i.e., TV,PVR,DVD, CBL/SAT,AUD,or VCR).
NOTE: To program control of a cable box or
satellite receiver, press CBL/SAT once.
NOTE: To program control of a CD player or
audio receiver, press AUD once.
NOTE: To program control of a TV/VCR Combo,
press VCR once.After programming, you will be
able to control channel selection, volume, and
VCR functions.
NOTE: To program control of a TV/DVD Player
Combo, press DVD once.After programming,
you will be able to control channel selection,
volume, and DVD functions.
[3] Press and hold SET until the LED (red light)
blinks twice, then release SET.
[4] Use the Manufacturer's Codes to locate the type of device and
brand name and then enter the first fourdigit
code for your device. If performed
correctly, the LED will blink twice.
NOTE: If the LED did not blink twice, repeat steps
2 through 4 and enter the same code again.
[5] Aim the remote control at the device and
press POWER once.The device should turn
off. If it does not, repeat steps 2 through 5,
trying each code for your brand until you
find one that works.
NOTE: If the device does not have a POWER
key, press the (Play) key.
[6] Repeat steps 1 through 5 for each device you want to control.
OK.
How do I program the oversized brookstone tv remote control to my new Samsung television?
Step 1: Turn on the device you wish to program (TV, VCR, DVD) manually
Step 2: Press and hold the button for the device you wish to program for more than 3 seconds, the red LED will illuminate indicating that the remote is ready to accept a three digit code.
Step 3: Enter the first three digit code listed below within 30 seconds, the red LED will shut off indicating that the remote is programmed.
Step 4: Press the ON/OFF button to verify correct code entry. If the device shuts off then no further programming is required.
Step 6: If the device does not respond, repeat steps 2-5 using a different three digit code.
Samsung - 043, 048, 054, 057, 062, 073, 074, 075, 078, 080, 089, 092, 097, 104, 112, 117, 118, 125, 131, 139.
What are the codes for a 153639?
wtlc50
I have provided a link for instructions on how to program your remote. You weren't clear if you were having problems with the remote working on your receiver or your TV. Step 5 is for programming the remote to your receiver, with step 6 programming the remote to your TV. I have also provided a link with the codes for the different TV manufacturers.
Readdress remote to receiver (step 5) / program to TV (step 6):
http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
Ray Calo
DISH Network
IR Remote Control Remote Control: my control is not working...
Guest
I have provided instructions on how you can program your remote to your TV or readdress to your receiver. Readdressing your remote to your receiver begins with step 5; programming to your TV begins with step 6.
Program remote: http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml
I hope this helps.
Ray Calo
DISH Network
How to program remote
Hello, Below is a clickable link from the SONY web site that shows step-by-step how to program your RMEZ4 Remote Control.
It's very easy to access and use.
I hope this helps you!
- CBR2009
http://esupport.sony.com/US/perl/model-remote.pl?mdl=RMEZ4
10helpful
Can't program my Toshiba CT-90302 remote to my DirecTV reciever?
step 1, select the funtion you wish to program on left side.
step 2 hold down the recall button while entering the 3 digit code for the device you wish to program
step 3 have a beer, you are done
Here is the link for the owner's manual that also has the codes
http://remotes.com/remotes/documents/Toshiba/CT-90157.pdf
2answers
Can't program Omega URC-06 remote control
try contacting remotes.com for the original remote control
3answers
Program my remot
http://www.directv.com/learn/pdf/System_Manuals/Hughes/HNS_SD_HBH.pdf
remote programming instrutions start on page 49 of the PDF file and give step by step instructions for programming your remote
Top RCA Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
