Posted on Jan 14, 2011
The flat cable at the back of my technics hi fi , model number SC- EH790 is broken ( the connectors have come away from the actual cable) do you know if I can get a replacement cable/connectors anywhere please. liz walsh
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 26, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
626
Points
0
I've got a technics hick seperates sch510 and I need the ribbon connecters wot go at the back to power each seperates were can I get these from please
4 Related Answers
Michael Borelli
  • 979 Answers
  • Posted on May 01, 2008
SOURCE: Hi i have a technics
Not available, sorry...
Anonymous
  • 624 Answers
  • Posted on Nov 09, 2008
SOURCE: Hi I own a Technics Hi-Fi
Any powered sub-woofer will work with it. Check the back of the Technics, make sure there is an RCA output labeled "Sub-woofer" or "Woofer" or "Sub". If so, you can get any brand of powered sub woofer and it will work. A powered sub-woofer is one with an amplifier for the sub built into the box and you will need to plug it into an A/C outlet as well. The only exceptions to what will work with this unit is to make sure you are not buying a sub-woofer that is made to only work with the companion unit it is originally sold with. Many Panasonic and JVC sub woofers are like this. Just look for a sub-woofer that is not part of any system. Velodyne makes some really great sub-woofers that would work nice with yours, but they can be a little expensive, but they are very good.
If your Technics has no RCA output for the sub-woofer, you will need to make sure that whatever powered sub-woofer you buy has a speaker level input for it. Most powered sub-woofers have this feature, so that you may just run the front speaker outputs of the receiver into the subwoofer and then the sub-woofer will have a set of speaker outputs right below the speaker inputs so you can still have your front speakers connected to that and not loose anything from your system.
I hope I have explained this in a manner you will understand easy, if not just post whatever questions you may have right on this thread and I will get back to you as soon as possible.
It would also be appreciated if you could rate this solution if you no longer need any help from me. If you do require more help, please wait to rate this until we are finished. That way I do not get an undeserved bad rating when we have not even finished our communications.
By the way, A "Thanks for trying" and "Helpful" rating are really not good, they always end up lowering my overall score.
Dave
Anonymous
  • Posted on Dec 03, 2009
SOURCE: Require a cable for Hitachi
anyone knows where i can get a cable for a hitachi hi fi midi system ax-m68d model
Anonymous
  • 8546 Answers
  • Posted on Jul 14, 2011
SOURCE: How do I connect my
Any audio device that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to any audio device with a standard RCA input (except one labeled "PHONO"). Get a cable like the one described here: http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT one labeled "Phono".
Top Technics Audio Players & Recorders Experts
Sudeep Chatterjee
Sudeep Chatterjee
Kolbrun...
woodzowl307
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
