Car Audio & Video Logo
Posted on Jan 14, 2011
What is the correct fuse size for a blaupunkt kdb 951 804? The radio is in a '66 Austin Healey 3000
5 Related Answers
Delage guy
Delage guy
  • 167 Answers
  • Posted on Apr 01, 2010
SOURCE: Midget 3UK Austin Healey Sprite 1967 to 1969
Send me an email ( crazeerooster@gmail.com) with your contact and I will scan one and email it to you, I'm heading out of town for Easter so may not reply for a day or two.
Cheers Marshall
Steve Banks
  • 232 Answers
  • Posted on Jul 31, 2011
SOURCE: I just bought a 1961
It could be a bad earth, this will make the fuel gauge either not work or work erractically.
Fuel gauges on older cars are pretty basic.
I'd be checking all my earth points, I'd also be looking at the fuel sender in the tank. It is possible that with all the work it has had, the wire has worn out. It is just a basic rheostat of a single piece of thin wire attached usually to a ceramic block at either pole. Most often this wears through and when that happens you will some times see either no gauge activity or it will work fine from empty to half but not beyond that. Also some times it works great from full to half then plummets to empty. Generally this is where it is worn.
If your serious you could take your fuel sender and gauge to someone who can recondition instruments, and have them reco'ed as a set.
Anonymous
  • 1833 Answers
  • Posted on Aug 12, 2011
SOURCE: 2000 Holden Astra - Hi there, I require a radio
If you have removed the radio from the car or changed/disconnected the car battery sometime back then you need Jaguar radio unlock code to get the sound back. You can purchase it from here.
There are few ways to unlock the radio
1. Refer to your manual. You must be having the code as well as the procedure to unlock it.
2. If you do not have the code then you can purchase it online. You will get the code within a day. For that you have to collect 2 information.
a. VIN - Vehicle Identification number, usually found at the bottom of the driver side windshield.
b. Radio serial number. You can get it on the top of the radio after removing it from the car.
c. You can purchase the code from here.
skychief2001
Stephen
  • 21873 Answers
  • Posted on Sep 09, 2012
SOURCE: austin healey hot start problems
Can you tell if you are loosing spark to the plugs or if the fuel in the carb is boiling ?
mccluskey1
NOEL
  • 8606 Answers
  • Posted on Nov 30, 2016
SOURCE: what is the maximum speed of austin healey sprite 48 hp 1961
Testimonial: "thanks"
Top Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
