SOURCE: Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
SOURCE: xerox 7232 workcentere cannot send emails
Judging from what you've said, I would say this is a setting on the printer. You need to make sure you have the outgoing address correct. Basically go into your printer settings with your E-mail server IP's.
SOURCE: Error Code 07,010.43:15005
7,010.43: The Printhead is stuck in the tilted position, or is not able to tilt
forward to the print position, due to problems.
SOURCE: xerox worcentre 3319 vista drivers
humm.. I do not recognize this model. But I guess this could be usefull
SOURCE: My xerox worcentre 103f shows the errors e7 - 15
The error code e7-15 is a copy lamp problem. There is a list of error codes for the Workcentre 100 series at this link.
http://www.partsdrop.com/pages/XD100inf.html
