Televison & Video Logo
Posted on Jan 17, 2011
Error code 06-0 when I try to access planner to record programs on my sky plus box
5 Related Answers
Anonymous
  • 3 Answers
  • Posted on Apr 11, 2008
SOURCE: Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
GSAN
Gerson War
  • 106 Answers
  • Posted on Jun 12, 2008
SOURCE: Recording from Sky+
could be possible that Sky TV is right protected therefore making it hard or impossible to record.
A
Anonymous
  • Posted on Jun 14, 2008
SOURCE: Connecting TV-DVD recorder-Sky plus
scart from the sky to the dvd recorder. then a scart from each to the tv. Job done.
asjadm
  • 101 Answers
  • Posted on Oct 28, 2008
SOURCE: Sky Plus Planner shows message
try formatting your hard drive, you will loose all the saved programmes but it may fix ur problem.
follow instructions:
http://nice-design.co.uk/blog/sky-plus-system-fault-how-to-fix-faulty-sky-without-a65-callout-fee
Anonymous
  • 687 Answers
  • Posted on Sep 28, 2009
SOURCE: recording from sky planner to dvd
Yep all you will need is a DVD recorder Philips do a good low cost version DVDR 3380 and a Philips DVD+RW ( this is the type that you don't need to finalize before you can use it in your PC)
All you have to do is make a connectiion to the video out of the Sky box using the suitable connection normally a SCART lead in to the EXT1 or EXT2 of your DVD recorder.
Play the Sky program in your planner and hit record don't forget to select the time you require 1 (HQ) 2,4 or 6 (SLP) hours. It will take as long as the program take to run to record it.
The best way to get the DVD-Video into your PC is to use the excellent TMPGEnc v4.0 Xpress from Pegasys use the Souce Video Wizard.
Then select the DVD-VR button this will read in the DVD content and then allow you to edit it and re-encode to almost any format.
If you select over 4 hours or recording most DVD standalone recorders will revert to Half D1 this equates to 360x576 instead of the Full D1 resolution of 720x576 (standard PAL for DVD-Video) you will need to use this filter to convert the half to full download it here Half D1 to Full D1
LOL
Testimonial: "Great!! very helpful, thanks for your help."
Top Televison & Video Experts
ADMIN Andrew
ADMIN Andrew
Larry
ADMIN Eric
ADMIN Eric
