Back to the top
Option 2: Starting the Windows Recovery Console from the Windows XP CD-ROM
loadTOCNode(2, 'moreinformation');
If
you have not preinstalled the Windows Recovery Console, you can start
the computer and use the Recovery Console directly from your original
Windows XP installation disc. If your computer is already in Windows
and you want to add the Windows Recovery Console as a startup option,
go to the next section "Adding the Windows Recovery Console as a
startup option."
xmodem—(AllCisco 2600 series routers) Use this command to copy a Cisco IOS imagefrom the console, if the computer attached to your console has aterminal emulator with Xmodem capability. See the "Copying an Image from the Console Using the xmodem Command" procedure.
Note
Downloadinga Cisco IOS image from a console is very slow. This procedure should beused only in an emergency and is not recommended for normal Cisco IOSimage upgrades.
tftpdnld—(ExceptCisco 2691) Use this command to copy a Cisco IOS image from a TFTPserver that is accessible through the FastEthernet 0/0, Ethernet 0/0,or Token Ring 0/0 port. See the "Copying an Image from a TFTP Server Using the tftpdnld Command" procedure.
Note
Thetftpdnld command is not available on the Cisco 2691 router. Therecommended method for installing a Cisco IOS image on a Cisco 2691router is from a CompactFlash memory card loaded in the externalCompactFlash memory card slot. See the "Entering Boot Commands" procedure. 106 views
