You need to first plug a mic (or guitar) into an input. Then you have to assign that input (A or B) to a track. You do this by selecting the input (pressing the input's assign button) and then selecting the track (pushing the tracks select/rec button) above the track. The track select button will light green when you press the input assign button of the input assigned to it to show where the input is assigned. (To unassign the input simply press the lit track select button again while the input assign button is pressed).
Then you have to select the track for recording. Simply press the rec button above the track alone and it will light red and stay lit. Now press the play and record buttons and you'll be recording.
Hope this helps.
bd.
Register and download the manual for free audio.manualsonline.com
http://music.manualsonline.com/manuals/mfg/tascam/dp-02cf.html
http://dl.owneriq.net/5/596f1517-7f90-4719-9803-1792891188c1.pdf
Page 16 Press the Record key by itself to place it in Record Standby mode.
dp02cf doesn't playback...levels show sound is there, recording...but no playback.
