Microwave Ovens Logo
Posted on Jul 18, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code F3H on model GH5184XP - Whirlpool Microwave Ovens
  • Anonymous Apr 29, 2009
    I don't have the model number with me, but I had that problem yesterday when I tried to reheat using "sauce." Then I just tried cooking, and although the timer set, no microwaves heated my sauce -- it was still cold.
William Miller
Level 3:
  • Whirlpool Master 9,179 Answers
  • Posted on Jul 21, 2008
William Miller
Whirlpool Master
Level 3:
Answers
9179
Questions
Helped
4550754
Points
21750
F3H is a humidity sensor error.
You may be able to clear the error by unplugging the oven for a couple of minutes. Then plug it back in, reset the clock and try again.
If it still has the error after a reset, please write back so we can give you another suggestion.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
1 Related Answer
Anonymous
  • 446 Answers
  • Posted on Nov 26, 2008
SOURCE: microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Microwave error message F7
This is for whirlpool models.Try this procedure and see if it helps.what is your model?
Models: GH9177XL GH5176XP GH5184XP GH6178XP GH6177XP
KHHS178L KHHS179L
Microwave will not operate (cook). F7 error code
appears on the display.
Electrical circuit interruption between L1 and Neutral in
the microwave inverter circuit.
Possible reasons:
1. Check door, hinge and cavity front alignment and adjust
as needed.
2. Check the operation of all interlock switches.
3. Check over temperature protector for the magnatron.
4. Check all Cavity Thermostats for closed circuit.
5. Unplug the oven for at least 40 seconds. If this solves
the problem
A. Check the Cooling Fan for proper operation or
blockage
B. Check the resistance of the magnetron thermostat.
It should be 0 Ohms, replace if necessary.
6. Check that the control cable to the 1100 watt inverter
is properly connected to plug P2 on the display PCB
& Adjust or Reconnect
7. If interlock switches operate correctly, replace 1100W
inverter.
8. If problem persists, replace control assembly.
Microwave - Kitchen Aid KHHS179LSS4 ERROR CODE -
Hello there Jerry
Sorry it took so long getting back to you i just finished moving into my new home and just got my internet today ok ill send you a troubleshooting steps
However this error code usually turn out to be a problem with the controle panel of the microwave and the only fix for these is to replace the part ok i will post the rest of the troubleshooting steps in a following comment ok
Best regards Mike
2helpful
Kitchenaid microwave khhs179lss-0 has error F3H
Hi, F3H mean that Humidity Sensor Failure. You have to refer to the Tech Sheet and test the sensor.
-F3H- WHAT DOES THAT MEAN- I was trying to cook frozen veg and it shut off and had -F3H- I canceled and tried it 3 more times and did the same thing-I have a whirlpool gold model #gh9185xlq-0
That means your humidity sensor is failing or has failed.
You can find helpful exploded view diagrams and order parts by entering your full model number (without dashes) or by part number (4393808) here.
5helpful
2answers
Whirlpool Microwave error F3H
F3H Humidity sensor failure 1. Unplug microwave oven or disconnect power.
2. Connect a new sensor to the board (at P5).
3. Plug in microwave oven or reconnect power.
4. If no failure code appears when starting sensor function:
 Replace old sensor.
5. If failure code appears when starting sensor function:
 Replace power supply board.
6. Plug in microwave oven or reconnect power.
1helpful
Error f3h on microwave
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
9helpful
Error Code
I would recheck the control board installtion that you made, as well as verify that you got the correct replacement. Also the board may contain static sensitive componets so you might want to make sure you are grounded when handleing the control panel. Good luck
12helpful
2answers
Microwave troubleshooting
I found the fix to the F3H error on another site. Just turn the power to the microwave off for ~2 minutes at the circuit breaker, and then turn it back on. Microwave will start working again then.
Top Whirlpool Microwave Ovens Experts
gerbee gomez
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
