Error Message in Windows 7. Your computer's system firmware ... manufacturer to obtain a firmware or BIOS update. (Code 35 ... also needs a BIOS update to be compatible with the FX540.
im not familiar with this type of error you might just try the to troubleshoot the problem until you no exactly what has caused the problem you cant fix
click start control panel administrive tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured you might have to uninstall then reinstall the program and its files
you could run the check disk utility
click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive or
control panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
hope this helps
