Car Audio & Video Logo
Posted on Jan 28, 2011
How do i remove the rear speakers in 2009 chev aveo sedan to replace them
5 Related Answers
Anonymous
  • Posted on Oct 13, 2008
SOURCE: rear door speakers
It's worse than that. Those are not "tamper-proof screws", those are aluminum pop rivets. (Then again, they are even more tamper-proof than screws.) Once you get the door panel off you will see that each rivet splits into four legs that splay out to hold the speaker frame sandwiched between the grill and the fiberboard door panel. You can remove them but it took me some time with stout needle-nosed pliers to un-splay the legs, and ultimately a Dremel tool to cut them off. What a cheap PITA way to attach a speaker.
Theoretically, you should be able to replace the OEM speaker with a skinny 4" one but you will need to fabricate an adapter ring so there is something solid on which to mount the new speaker. Also, you will need to tape flat Tinnerman nuts to the back side of the panel so the screws you shoot through the grill will have something to bite into. It won't be pretty but it should work.
Anonymous
  • 462 Answers
  • Posted on Jul 04, 2009
SOURCE: what torque spec for chev aveo 2004 cylinder head
18 lb ft+60°+60°+60°+10°
NEW HEAD BOLTS ARE REQUIRED WHEN REPLACING THE HEAD OR HEAD GASKET.
tntjasmine
tntjasmine
  • 24 Answers
  • Posted on Aug 26, 2009
SOURCE: Rear speakers for Chevy Aveo
you can access them from under the package tray inside your trunk compartment
Anonymous
  • 564 Answers
  • Posted on Dec 29, 2009
SOURCE: cant remove the tail light assemblies on '09 accord sedan
youll have to pull up very firmly or it may have to slide to the side its held in place by a bodyfastener. a screw that fits into a slot. but i would try pulling up first.
Jonah Oneal
  • 14092 Answers
  • Posted on Mar 04, 2010
SOURCE: how to remove rear axle to replace axle seal?
YOU NEED A HAYNES OR CHILTON REPAIR MANUAL.TO REMOVE REAR AXLE YOU HAVE TO REMOVE REAR DIFFERENTIAL COVER AND GASKET.YOUR DIFFERENTIAL HAS EITHER PINION SHAFT LOCKING SCREWS OR C - LOCKS.THEY HAVE TO REMOVED BEFORE AXLE SHAFT WILL COME OUT.
Top Car Audio & Video Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
