Once a jet face has fallen out of a hot tub that means the insert has failed and is broken. you will need to locate a new jet insert. Jet inserts have little tabs on them that hold them in place and when they get worn out the jet face will fall out into the tub.
Testimonial: "Thanks very much. I was kind of guessing that those two little nubs of ear tabs had some purpose. I'll search out new parts."
Take a rubber band and wrap the base of the jet so it fits tight then push it into the seat, this worked for my jets on a hydrotherapy spa if that don't work take astandard size rubber glove and cut off the fingers at the knuckles..then slide over stem of jet, cutting out any notches for waterflow..push jet back in.bada bing...been workingfor 3 years now on a tropic seas hydrotherapy tub. 40 of the 65 jets were flying off,factory wanted 4.00$ a jet said due to water quality after owning it a year ...works perfect and still allows you to twist jets on and off...
