SOURCE: can the clix gen2 play avi. files without converting?
Even though they may be avi files there are different codecs that may have been used to encode them. Since the specifics are a little too much to type here I have put a link to a faq on the clixhere! forum below.... they has all the specifics and can even help you if converting is needed. Clixhere!
SOURCE: Converting files
You must click "Add", then you click the button behind "Source File" in this dialog you search your film and then click "Open"
then click the button behind "Target File Path" and then you can
choose the path, where you will save the file then you can
set quality and the aspect ratio, but "High" and "Full" are ok.
then you can click "Save"
then you can add other films on the same way how i explained you. When you have all films, which you want convert you click "Close"
and then you click "Convert Now".
Then convert the converter your films.
With the button "Stop" you can stop converting,
with the butten "Del" you can delete the film, which you not any more want convert. With "Close" you can close the Programm.
SOURCE: RE: GPX Touchscreen Media Player
you will need an advanced movie editor or converter that can convert the video from the supported types(even if it is already an .avi file) to: 320x240 resolution, using the xvid mpeg4 codec for video and mpeg layer3 mp3 audio codec. the quality can only be as high as 64 kbps i believe.
the player itself comes with a converter either built-in or on a cd. this converter sucks though and wont sync up the audio to the video very well at all. so i suggest you use a high quality converter so the videos will be watchable.
