Bugaboo Bee Umbrella Stroller Logo
Posted on Feb 19, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do u close a blue bugaboo bee ? - Bugaboo Bee Umbrella Stroller
Stephen Faulkner
Level 2:
Guru:
  • Expert 541 Answers
  • Posted on Feb 24, 2011
Stephen Faulkner
Expert
Level 2:
Guru:
Answers
541
Questions
Helped
242785
Points
983
Bugaboo bee 09 rear wheels
Yes the Bee+ wheels fit you need two 4 mm alan / hex keys to take off the wheel. You could just change the bearings they use a 608zz bearing any bearing or skate board shop would sell but you may need to add a few spacing washers as the Bugaboo bearing has an extended core.
Bugaboo bee clamps
Hi, All you need to do is to contact www.bugaboo.com and they will be able to sell the part to you directly. Hope that helps.
Bugaboo bee pram won't fold - the white button has jammed. How do I releas it?
Not an easy fix the handle unit is all closed in with pop rivets so you need a drill and pop rivet gun just to open it. Try spraying silicon spay in to the inside of the handle where ever can then pull up ******* the release buttons while flexing the joint back and forth.
Can we use maxicosi mico car seat on bugaboo bee 2009 stroller?
Not sure on the Bee 2010 but all Bugaboos require an optional (you have to pay extra for) set of car seat adaptors. Check out www.bugaboo.com if they are not selling an adaptor set for your bee the answer will be no until they do.
1helpful
Do the 2009 bugaboo bee maxi cosi car seat adaptors fit the bugaboo bee 2010? Thanks
I haven't worked on a 2010 (yet) But I'm 99.9% certain you'll have no problem Bugaboo are good at keeping mounts standardized unlike some makes where each year it's virtually a different stroller. With chain store brands they usually are.
Does a kiddyboard bugaboo fit to bugaboo bee?
In short, no. There are no buggy boards that are suitable for the Bee.
Hope this clarifies this for you.
Bugaboo bee- one of the sides on the handlebar stopped locking in place (clip doesn't stay closed). It makes it akward to push. bugaboo won't issue replacement part since I bought off craigslist. Help,...
It should be cover under warranty so take it back from where you bought it and ask them to send it back to Bugaboo to have it fixed free of charge. Visit me at www.buggypitstop.co.uk if you need any more advise
10helpful
Faulty Bugaboo Bee
I to had this problem, my problem was i also lost proof of purchase so couldnt get a new chassis, Bugaboo even though the prams havent been out for two years wouldnt replace so i had to try and either fix the pram or buy a new chassis for £235. I then read on the internet about how to remove the rivets on the chassis, you need a rivet gun and a drill the problem was the rubber had broken and fallen way down the pram chassis and if you can replace this with some new rubber the chassis is good to go (just make sure you do this slowly so you can see what part goes back where), you need to buy new rivets as when you remove the old olds these are no longer useable, i am soo happy i tried to fix this, it took me and my sister 1/2 hour and saved me £235 (the price quoted by Bugaboo for a new chassis). Hey hope this helps anyone and saves you having to line Bugaboo pockets, hey theres a clearly a niche in the market as Bugaboo do not have a work shop, they clearly want you to keep spending!!!!
Top Bugaboo Baby Gear Experts
ADMIN Andrew
ADMIN Andrew
john h
Paul Carew
Are you a Bugaboo Baby Gear Expert? Answer questions, earn points and help others
