Hello
Three digit universal remote codes for Sansui are:
135/ 136
Four digit universal remote codes for Sansui are:
0135 0310
Direct Code Entry
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search. OK
Universal remote codes are determined by the maker of the universal remote, not the maker of the tv, unless they are both made by the same company. Determine the maker of the universal remote and it's model number, then go to the universal remote makers website and look for codes under the name of the tv (or dvd, vcr, etc) that you want to program the universal remote to operate. Programming instructions should be on the universal remote makers site as well.
I hope this helps.
BobYa
The codes I've send to you must work, and have reports about it with me. Do the proceedings keenly. I'm not sending these codes non ony to you.
