Hi, Here is a tip that wrote about how to
buy heating and air conditioning parts online.
There are many website that will sell you a gas valve on line....
How
to find Air Conditioning, Heating and Furnace parts online.
Now as far as the install goes....
First you need to turn off the gas and electric to your boiler..
Then mark all wires to the old gas valve so you can get them back on where they belong again...do not rely on your memory!!!
You will then need to remove the gas line from the gas valve...and also remove the gas valve from the manifold...before to use two wrenches so you so not twist everything and wreck things...
When installing the new valve. you will need use pipe dope on the threads that is approved for gas....also do not use any teflon tape that is not approved for gas!!! Gas approved tape will be yellow in color...
Reinstall the gas valve and then the wiring again...
Use soapy water with the gas on again to check for gas leaks before refireing the boiler...
Heatman101
I will try to do some research on that tonight... need to run today and change a hot water heater for some people with no hot water...
The problem with the Bryant is just as I'm sure you have found out....you cannot usually replace with just a generic valve...I will have to see if they are making a replacement valve...
Here you go....
The same valve for a LOT less money!!!
http://www.grainger.com/Grainger/ROBERTS...
heatman101
Accepting the solution gives me a positive rating... Thanks!! and hope it all works out for you...
On the road so I'm using my phone ...but the short answer is, that you often have to install a union to get everything to work.
Great... also place a thin layer of pipe dope on the threads, the beveled edge, and the backside of the ring of the union so that it get tight enough and does not leak...have found many leaks at unions...spray all of the joints with soapy water after turning th gas on and before firing the furnace... dish sopa and water works great!!
Sorry... I have driven over 2000 miles this past weekend going to and from a wedding...
Contact me @ heatman101@yahoo.com
Heatman
I am looking for a specific answer to the question of what Gas Valve should I buy to replace my Bryant 1/2 A643 Gas Valve on my 234 4PW Series E boiler. I appreciate the generic response on finding the info and installation (both of which I already know how to do generically) but am look for more specific help since the A643 is obselete.
Rgds
David
Ok thanks - I found a pricey $250 RobertShaw unit in AmericanHVACparts.com that's listed as a replacement for the A643 but am looking for more options
Here's the AmericanHVACparts.com link to the only unit I found:http://americanhvacparts.com/Merchant2/m...
Pricey! $250 for a gas valve - looking for alternatives
Thanks - I bought the Robert Shaw valve
Thanks - here's a quick update - my HVAC pro finally obtained this replacement Carrier part number EF53CK198 from the Bryant dealer at close to $400! We looked online and found/bought an exact EF53CK198 replacement RobertShaw unit (Robertshaw 700-416 Model 7000BGVER-S36) at around the same price as the unit you found at Grainger. Will let you know when how it fits when I get it installed.
Thanks for your help. I accepted the solution and will be glad to give you a positive rating (except I am not sure how to do that!)
Rgds
David Lee
Yup got it! By the way, I bought all the appropriate length pipes and have a question. Here is the sequence of pipes/valve that I have connecting the FIXED supply side T junction on the left (with a Female 3/4") and the FIXED furnace side pipe on the right (with a Female 1/2"):
3/4" x 3" nipple dual Male - TO -
3/4" to 1/2" Reducer dual Female -TO-
1/2" x 2" nipple dual Male -TO-
1/2" to 1/2" valve dual Female -TO-
1/2" x 4" nipple dual Male
Try as I may, I cannot visualize how to connect the last component since it will thread in on one side and thread out on the other!!! Am I going nuts?
Thanks - a union is what I forgot to buy. Will get that today.
Got it - done and worked well for over 2 months - now another problem with a load bang on startup. Decided it's time to spending good money and went to Home Depot and bought a new Slant/Fin S-120 90k BTU new boiler. Looking for advise on updating the code around the unit (low water cutoff, auto-fill with backflow, new expansion tank etc.). I will put out another premium request if you wish or we can do this directly.
