SOURCE: Watch Band Adjustment
I just got this watch for a gift and was able to remove links myself after doing some research. It really isn't difficult if you are patient, have a little mechanical experience, and have some very basic "tools" available.
Tools:
Try to pick a well lit table in a room where you will not be interrupted.
Procedure:
1. Lay the watch and band sideways on the block of wood so that a pin for the link you would like to remove is just hanging over the edge of the block and pointing down. You need the block to brace the band while you hammer lightly on the pin. Someone to hold the watch in that position would be helpful, but it can be done alone. Only try to remove pins that have an arrow on the back of the band pointing at them. It does not matter with this watch band which way you go with the pin.
2. Carefully line up the push pin point with the top of the pin.
3. Slowly, lightly and carefully hammer the plastic side of the push pin so that the pin in the link just emerges from the band on the bottom side enough so that you can grab it with the small pliers.
4. Slowly and carefully pull the pin straight out with the pliers. You can pick up the watch from the block of wood to get a better grip. Be careful not to bend the pin since you will need to replace at least one of the pins you remove.
5. Repeat steps 1 - 4 until the band is the correct length. I needed to take out 3 so I removed 2 from one side and 1 from the other side of the clasp.
6. To fasten the watch back together again, gently insert the pin back in the hole it came from it. You will probably need to use the tack hammer to make the top of the pin flush with the band.
I think maybe we're all too familiar with the little old watchmaker image, loupe in right eye with tiny tools at hand......The links that have the arrows on them are indeed removable, it just takes more force than you might think. I'm in my office, so I used a pushpin (like for bulletin boards) and yep, it took more force than I thought, but the pin did come out the other side. A little tug with needle nose pliers and out it came. Remove link, repeat as necessary. Good luck
SOURCE: Need a new back for my Relic (Susan G. Koman) watch
The only way I can see is to try to contact FOSSIL (Relic are made by Fossil).
You will find Customer Support as well as How to contact etc.
The link is here:
www.fossil.com
If you can't find what you want, send an email to them explaining what exactly you are looking for.
Do not forget to rate, please.
SOURCE: taking back off relic watch
If this is screwback, then there should be grooves for inserting case
opener claws. For this yoy need case opener with interchangeable claws.
You can buy it on ebay for approx. £7.00.
If the casebask is
snap-on, then there shouldn't be any grooves, just small opening (lip)
between the caseback and case. This is exact point where the
watchmakers knife blade must be inserted and pryed up.
SOURCE: How to adjust Relic ZR15539 watch band
Depends on the type of band. Is it a twist-o-flex or solid link? Your best bet is to seek out a local watch repair business and let them adjust it for you! Unless you do these often it can be frustrating and you could lose small parts!
