Posted on Mar 20, 2017
Hi There I purchased an AF 3iP Micro System last July and love it, except that that I am unable to play soft music on the cd as there is a loud mains hum.. Everything else on the System is good. My daughter who purchased hers at the same time has the same problem which I presume is a manufacturer fault. I have had it back to **** Smith's twice but the problem has not been resolved. Thank you for your time and resolution Best Regards Julie I am wondering where I go from here please. My first option was to go through you and then Consumer Affairs if it is not resolved. I do not want a replacement as there seems to be a fault with all of them. I can be contacted on 0418 613 093 at any time. Please leave a contact number and name if I do not answer.
5 Related Answers
Anonymous
  • 1463 Answers
  • Posted on Feb 26, 2008
SOURCE: Setting the clock on a Philips MCB240
hi
will this help
a user guide download and search the clock settings hopefully this will solve it .
PHILIPS MCB240 Micro Hi-Fi
riz.
Anonymous
  • 4234 Answers
  • Posted on May 28, 2008
SOURCE: CD does not play
This sounds to me like the loading mechanism is having problems. It may be as simple as the grease gumming up a bit, or the motor having a dead spot. Without seeing the machine itself, it is hard for me to say. I'd rebuild the loading mechanism and regrease it. Figure on the local labor rate for this repair as no parts should be required unless the motor has failed.
Dan
Anonymous
  • 9 Answers
SOURCE: SMS Contact names display instead of numbers please
I got a better solution for you. Its because the iphone is not designed for Australian phone numbers. Mine was the same.
On your installer add the source installer.iclarified.com
Then add a package called appsupport 1.1.4 and voila, your contacts will match up with your sms's and call logs automatically
Anonymous
  • Posted on May 24, 2009
SOURCE: jvc xlmv33 three tray karaoke cdg player
I took it to a repair shop, found out it would be very hard to fix due to age. could not get parts for it, so I will just get a new one.
Thanks for the suggestion
Anonymous
  • 14 Answers
  • Posted on Aug 18, 2009
SOURCE: Drum set keeps going out. I purchased the first
Hi-
You can repair your drums actually for pretty reasonable!
Here is a link to a video on how to repair the drums yourself,
you'll have to purchase the cable yourself, but you can find one if you search eBay for "guitar hero drum cable"
I hope this helps!
Top Thomson Audio Players & Recorders Experts
SmartAviator
SmartAviator
Paul Bade
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
