Baby Gear Logo
Posted on Mar 04, 2011
How do I remove the rear seat of my 1995 K11 Nissan Micra to get to the Fuel gauge?
5 Related Answers
Anonymous
  • 685 Answers
  • Posted on Nov 11, 2008
SOURCE: fan belt
http://www.motorvate.ca/mvp.php/501 here is a good site for you
Anonymous
  • 507 Answers
  • Posted on Nov 05, 2009
SOURCE: 2001 Nissan Micra replace fuel gauge bulb
need to remove instrument cluster to get to globe from the back,should be mounting screws in front to remove around instruments
Anonymous
  • 677 Answers
  • Posted on Feb 08, 2010
SOURCE: i have nissan micra K11 with light flasing code
From what I understand it is the Nissan Anti-theft System (NATS) correct ?
The other numbers you show do not correspond to any codes I can find.
The reason the car is not starting is because the Nissan keys MUST be programmed for that car.
Make sure you did not have a new key made and that if you did you have to program it.
Your owners manual will tell you how.
Please elt me know what you find.
Testimonial: "thanks for your help, the car need key porgramer."
Anonymous
  • 188 Answers
  • Posted on Jul 21, 2011
SOURCE: nissan micra k11 99 wont
take off the distributor housing and dry it out, when putting it back on use a sealer to make sure no moisture gets in to it, then take out the spark plugs and allow the gasoline in the cylinders to dry out for about 20 mins then put back in and try starting it again that should definatly work
Vernon Taylor
  • 7446 Answers
  • Posted on Jul 16, 2016
SOURCE: Hi my 1998 Nissan micra k11 fuel gauge keeps fluctuating changes the sensor in the tank still the same
In a conventional system the tank sensor provides a variable ground path for the gauge which is fed by a stable regulated voltage from the instrument regulator. Sometimes the regulator will fail and cause a fluctuating voltage supply depending on engine speed, whether the lights are on or off and suchlike. Mostly such fluctuations, if they seem random, are caused by a less-than-perfect connection somewhere, mostly the fuel tank ground connection. Newer systems use a computer to drive the instruments but excellent connections are equally important..
Top Baby Gear Experts
ADMIN Andrew
ADMIN Andrew
john h
Paul Carew
Are you a Baby Gear Expert? Answer questions, earn points and help others
