T-View Dvd7905bd Car Video Player Logo
Posted on Mar 04, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bluetooth code - T-View Dvd7905bd Car Video Player
Anonymous
Level 3:
  • Master 449 Answers
  • Posted on Apr 22, 2011
Anonymous
Master
Level 3:
Answers
449
Questions
Helped
140258
Points
1193
Usb dongle is not working
Step 1:
A Bluetooth dongle is an external Bluetooth device used to enable your PC's Bluetooth connection. Many Bluetooth dongles come without installation disks since the software is pre-programmed into the actual USB stick. These Bluetooth dongles are very useful on netbooks that don't have Bluetooth connection, since netbooks have no CD-Rom drives. Turn on your PC. Insert the USB Bluetooth dongle into the USB port on your desktop tower, or the USB ports located on the perimeter of your laptop. Wait for the program to auto run. Once you connect your dongle, the driver program should launch. Follow the onscreen prompts to install the dongle. A dialogue box should open that says "Installing Drivers" from the taskbar. Allow the driver to install completely before closing the box. Unplug the dongle and restart your PC. Once the PC has been switched on, insert the dongle. Double-click "My Bluetooth Places." This is the Bluetooth icon located in your taskbar, and it should launch the "Initial Bluetooth Configuration Wizard." Click "Next" on the first screen. Next, type in the name of your computer and select your computer type from the drop-down menu, then click "Next." Click "Skip" on the onscreen prompts, then finish. Pairing the Devices Turn on your external Bluetooth device. Double-click "My Bluetooth Places." Select "Find Bluetooth Devices." The name your Bluetooth device should display in the next window. Right click the icon for your Bluetooth device, and scroll down to "Pair Device." Enter the Bluetooth pin code for your external device in the "Bluetooth Pin Code Request" pop-up window. Then click "OK." The default pin code is normally "0000" or "12345." You can find your pin code in your user manual. If you are pairing a cell phone to your PC, you will have to enter the same pin code on your cell phone to establish the Bluetooth connection.
Bluetooth pairing codes
If you are familiar with Bluetooth wireless technology, you'll probably recognize the term "Bluetooth pairing". But do you actually know what Bluetooth pairing means?
Bluetooth pairing occurs when two Bluetooth devices agree to communicate with each other and establish a connection.
In order to pair two Bluetooth wireless devices, a password (passkey) has to be exchanged between the two devices. A Passkey is a code shared by both Bluetooth devices, which proves that both users have agreed to pair with each other.
This is the normal process that occurs with Bluetooth pairing:
5helpful
3answers
I.Tech BlueBand Bluetooth Stereo Headphones whate is the pin code
Hi, In some states, hands free driving is the law. In order to avoid a ticket you need to talk on your cell phone with a bluetooth headset or speaker or with a headset that attaches directly into the phone. Bluetooth headsets are popular for this and other reasons but connecting it to your phone can be confusing. Here are some steps to help you connect your bluetooth device to your cell phone.
Instructions
Things You'll Need:
* Bluetooth headset
* Bluetooth capable cell phone
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Hope it helped.
And please don't forget to rate me...
Thanks and have a nice day...
2answers
Bluetooth passcode
To find a bluetooth passcode click tis link bp
to change passcode click tis cp
to reset rp
  • Step 1 Look on the back of your headset or speakerphone for the Bluetooth passcode for the device. Typically the pairing code for headsets is printed on a sticker that is then placed on the underside of the accessory.
  • Step 2 Go into the Bluetooth menu on your cell phone to find the passcode for your cellphone. The Bluetooth menu for your phone is typically located under the "Settings" menu. In the Settings menu there should be an option to "Get code" or something comparable, which would allow you to find the code for your phone.
  • Step 3 Go into the Settings menu for your computer to find its Bluetooth passcode. Some laptops will randomly generate a new Bluetooth passcode for you each time you want to pair them with a new device. In that case the menu setting you're looking for is something like "Generate new pairing code."
  • Step 4 Look in the instruction book for your Bluetooth accessory if you cannot find the passcode attached to the device or in its menu. Many manufacturers will print the passcode for devices in their instruction book. If you still can't find the passcode, try using all zeros.
  • Read more: How to Find a Bluetooth Passcode | eHow.com http://www.ehow.com/how_5169210_bluetooth-passcode.html#ixzz0vcmCZd00
    How i connect my note book to my htc bia bluetooth
    Hi,this is a detailed step on how to connect your htc to your notebook via bluetooth. STEP 1. Turn on the bluetooth of your htc which is accesed at the connnectivity settings of your phone.
    STEP 2 Ensure you also put on the bluetooth on your notebook,most notebooks have a single button in front of the keyboard,to turn on the bluetooth. STEP 3 You now go to the bluetooth settings on your phone,and click on 'add device'.when you click on it,it requests for a pass code,when this is done for the first time,this pass code can be any 4 digits of your choice. STEP4 After entering the pass code on the phone,a pop up shows on your notebook requesting for the same pass code you entered on your phone. Ensure you enter the same pass code for both the phone and notebook,if not the devices won't pair via bluetooth.
    STEP 5. After entering the pass code on the notebook,the notebook is automatically paired with the phone via bluetooth,afterwards you can be able to transfer files between the phone and the notebook via bluetooth.
    Thanks and take care
    5helpful
    2answers
    Bluetooth connection to my LG Renoir KC910
    Go into control panel, click on bluetooth icon. Tick box 'allow bluetooth devices to find this computor.
    Switch on bluetooth on phone and search for new devices. Message on computor, a device is trying to connect. click on message enter code, 0000. enter same code on phone when prompted (be quick).
    Start LG pc suite, connection wizard, click bluetooth then next, enter code 0000 when prompted.
    Look at phone enter same code, 0000, when prompted and hey presto all will work.
    Hope this helps
    Regards
    Max
    Bluetooth Pairing code
    pairing code or pass word for my plantronics220 bluetooth ear piece
    5helpful
    3answers
    Need code for my bluetooth
    you should put five times zero i.e 00000
    2answers
    Pioneer Bluetooth
    The Z2 default code is 1111
    Top T-View Car Audio & Video Experts
    ADMIN Andrew
    ADMIN Andrew
    ADMIN Eric
    ADMIN Eric
    Are you a T-View Car Audio and Video Expert? Answer questions, earn points and help others
