Actually mike is correct, you have to plug one into sata0 and the other into sata1. zero is master and 1 is slave. so you would need four sata ports on you motherboard.
Could be wrong, but i think you leave a SATA drives jumper on cable select. There is no slave as such..in terms of the old master slave of pata drives..running of the same cable..Good luck.
do you have two masters?
