True 49 cu. ft. / 1388 liter Commercial Freezer GDM-49F-RC Logo
KENNETH RHODES Posted on Mar 08, 2011
I HAVE A CODE FLASHING "HA"
What does a flashing code d5 on a Blue Air Commercial Freezer mean?
Question moved from Land Phones category.
CL is telling you to close the door. The is nothing about D5. Contact them direct.
Page 13 here
https://www.qremshop.com/wp-content/uploads/2019/01/Owners-Manual-BSF.pdf
Jan 14, 2022 • Freezers
Having restarted my upright Freezer how long will it take for the flashing red light to stop flashing
what was the reason for the trouble code --if problem not fixed trouble light will keep flashing if light flashing due to temp when setting is reached will stop
Error message ,HA on display of Arctic Air AF49
http://www.arcticairco.com/docs/reach-in-owners-manual.pdf PAGE NO. 9
Maximum temperature alarm, Outputs unchanged. I think your board needs to be reseted, but dont do it by your self, look for help.
Regards,
1helpful
Danby icemaker DIM3225BLSST, having drainage issues and trying to troubleshoot. Is the drain pump switch on if the "O" is selected, or the "----" ?
Thank you for being very descriptive. I would get the installer back out since it is new and probably still under warranty and instruct them to say with it until it has satisfactorily run a couple of cycles. They can easily troubleshoot this machine while they are on the job.
I have " E
E1 - Control board problem
Notes: C, E
C:
Disables clean mode in Thermador device, allows cook and microwave
E:
1. Turn the clock selector knob to OFF
2. "Tweak" the oven control by turning the clock selector knob slightly to the left
(counter clockwise).
This may stop the flashing message/beeping and clear the display window.
Hope helps.
I have an error code on my upright frigidaire freezer "CE". it holds the temp but this error code keeps flashing. how can I get rid of it?
I just unplugged mine and plugged it back in. It works fine now. The problem happened after a quick power outage.
1helpful
My true freezer temperature gage has a P1 flashing code
If unit keeps proper temp. then I would think that either the thermometer sensing probe may have been damaged during the repair process or the thermometer itself has failed.
Have a look at the Make and model of your thermostat and download the Instructions from the internet or give ur local refrigeration mechanic a call and ask him they are easy to set
FLASHING E8 (WARNING) ON MY FRIDGE FREEZER
A model number and serial number would help in any diagnosis.
May 04, 2008 • Freezers
Top True Freezers Experts
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
MUKHTAR
MUKHTAR
Level 1 Expert
Are you a True Freezer Expert? Answer questions, earn points and help others
