1) BOSCH error code A7: Outlet temperature sensor fault (Temperature below freezing or above 210?F).
http://www.boschhotwater.com/HelpfulResources/TechnicalSupport/BoschAquaStarModels/2400ESTechSupport/Troubleshooting/tabid/1295/Default.aspx
a. Check red wire connections at hot water temperature sensor. Clean terminals with an eraser. If badly corroded, replace sensor and wire harness. (See Fig. 63, page 46 in manual).
b. Sensor may trip if water temperature drops below freezing to protect heater from freezing conditions. Any damage due to freezing conditions is not covered under warranty.
c. Clean inlet filter screen and clear any debris out of shower heads, faucet aerators and whole house filters.
d. In areas where water has a high mineral content, periodic descaling (de-liming) may be necessary.
2) Bosch has online tech support form:
http://forms.boschhotwater.com/Home/BoschTechSupportForm/tabid/614/Default.aspx
3) Bosch problems at Fixya:
http://www.fixya.com/support/p949576-bosch_1600h_lp_liquid_propane_aquastar_a/solutions
4) Read manual cover to cover and make sure maintenance is scheduled.
For example de-liming is recommended each year.
Utube search de-lime tankless water heater
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
