Posted on Apr 04, 2011
There are error code sc 322-00 - Lanier 5235 Printer
RICOH Aficio MP W2401 FUNCTIONAL PROBLEM SC 401
Ricoh Aficio 240W Plotter Error Code SC 401-00
Copytechnet https://www.copytechnet.com > forums > 108927-rico...
May 4, 2016 - On old Ricoh Aficio's SC401 used to be a Transfer error, but on the 240 its ID Sensor, could be dirty, could be old Dev, could be a loose ...
Ricoh MP2352 SC401- Strange problem
Jul 28, 2021
Error Code SC-401
Sep 12, 2014
ricoh mp 3352 - error sc401
Dec 11, 2020
Ricoh mp 2851 SC 401
Jul 11, 2017
More results from www.copytechnet.com
Error Codes > Ricoh > MP2553 > Code SC401
Printcopy.info https://printcopy.info > code=SC401
Code: SC401 · Description: Transfer positive electrode current error A transfer roller current leak signal is detected. · Causes: • High voltage supply board set ...
Missing: W2401 ‎' Show results with: W2401
Error Codes > Ricoh > Aficio 2090 > Code SC401
Code: SC401 · Description: Transfer roller open error · Causes: • Transfer power pack defective • Poor connection between the transfer current terminal and the ...
Ricoh Aficio MP1600. Error SC 524?
Check out the links
Error Codes > Ricoh > MPC305SPF > Code 524
Printcopy.info https://printcopy.info > brand=Ricoh > code=524
Code: 524 ; Description: Transport motor error. The machine detects a High signal from a transport motor lock detection for 2 seconds after the transport motor ...
Missing: 1600. ‎' Show results with: 1600.
RICOH Error Code List - mtechsinfo.com
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF Image compression errorHard disk drive error Aficio 551, 551P, 700, 700P SC- ... SC-524. Duplex end fence drive problem. SC-530. Bypass motor locked or fuse FU106 ...
14 pages
Error Codes > Ricoh > MPC306 > Code 524-00
Printcopy.info https://printcopy.info > brand=Ricoh > code=524-00
Code: 524-00; Description: Transport motor error The machine detects a LOCK signal from Transport motor for 2 seconds when the motor is activated. https://www.google.com/search?q=Ricoh+Aficio+MP+1600.+Error+SC+524
and finally
https://www.mtechsinfo.com/files/Ricoh%20Error%20Code%20List.pdf
Ricoh Aficio. How I clear SC390 code? Print is clear, after 10 copies SC390 code is coming. How do I solve this problem please?
Question edited tor a lot more clarity and add MAKER, but NO MODEL NUMBER! All questions need full make and model.
Ricoh Aficio 200 - Error Code: SC390
PrintCopy .info https://printcopy.info > code=SC390
Code: SC390; Description: TD sensor error 1. The TD sensor outputs less than 0.5V, 20 s after the TD sensor initial setting has been performed.
Missing: cod ‎' Must include: cod
SOLVED: How fix sc390 cod of ricoh
Fixya https://www.fixya.com > ... > Ricoh
The closest thing is the sc390 code, which means either the toner density sensor or the developer has gone bad, and typically replacing the PCU can fix that ...
Error Code sc 390
Copytechnet https://www.copytechnet.com > 56632-sc-390-a
Sep 24, 2011 - I've got an Aficio 1018 that's generating sc390 after every 10 copies. I recently fitted new drum, cleaning blade and developer and changed ...
mtechsinfo.com http://www.mtechsinfo.com > files > Ricoh Erro... PDF SC-390-2. Toner density sensor error. SC-391. Developer bias problem or FU103 on Aficio 550/650 Image storage address error. Aficio 551, 551P, 700, 700P.
14 pages
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Error code sc211
This error code SC 211 not exist.Exist SC 2-11 is the communication problem.For reset the SC codes following the procedure:enter in the service mode (press total clear key-1-0-7-Clear keyhold down more 3 sec.Enter SP 5-810 SC code reset and select `1`.Then hold down the original type key and the OK key at the same time.This does not require the main switch to be turned OFF and ON.
11helpful
2answers
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
3answers
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
5helpful
2answers
Top Lanier Office Equipment & Supplies Experts
George Mclaughlin
ADMIN Andrew
ADMIN Andrew
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
