Health & Beauty Logo
Posted on Apr 06, 2011
I need to know how to fill the IGIA therma steam product. I have a very sick stray kitten with a bad respiratory infection and the vet has recommended a small space filled with steam. Your product will accomplish this. Someone left one off at my home, but without instructions. I don't know where to put the water into the unit. I also see there is a second resevoir. What is this one for? If you could get back to me soon, it would be greatly appreciated. Thank you, Sue Taylor
5 Related Answers
Anonymous
  • 878 Answers
  • Posted on Apr 15, 2007
SOURCE: Starts to fill and then stops, and the cycle continues on.
Jmars, under the consol there is two pressure switches. One controls the fill and the other is back-up incase the other fails. It sounds like your water pressure switch is tripping too soon. Try putting the washer into a self test mode by pressing in this order soak--soil level---soak--soil level. The machine should enter a test mode. Let it run it's test and see if you come up with any error codes. The pressure switch is the one on the left under the consol. It will be marked OPR, the part number is 8054766. The consol will lift up by using a putty knife under each end, pushin on the clips and lifting up. The back panel of the consol is removable. Catriver..post back
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Dec 27, 2008
SOURCE: Detergent dispenser is filled with water after wash is completed.
The water is left there because the syphon action is not working in the dispenser, what you need to do is to remove the dispenser drawer completely and thoroughly clean the conditioner compartment, poking any holes or tube, particularly the syphon tube with a piece of flexible wire or similar to ensure it is completely unblocked.
. to test, fill the conditioner compartment with water, and it should slowly empty itself, if it does not, then it is still blocked.
Plz rate this solution.Thanks.
Anonymous
  • 462 Answers
  • Posted on Mar 12, 2009
SOURCE: Kitchenaid stand alone ice maker.
Check and see if your cutting grid is still lined up on the back side towards the freezer plate. I have had the cutter miss align on some and failed to see it then just have to remove the thumb screws and re set the back end. Feel for more roughness from scale. Especially on the sides and edges. you may need to clean it again
This unit I believe is set to allow water in when it goes through a harvest. it wont refill until the coldest temp is reached then will stop filling after the warmest temp is reached.
Anonymous
  • Posted on Oct 11, 2010
SOURCE: looking for an instruction manual
These are available for free from NordicTrac. Visit - http://service.nordictrack.com/CustomerService/manuals.do?dr=NT
Anonymous
  • 12 Answers
  • Posted on Nov 17, 2010
SOURCE: The machine will say Fill water tank. So, we will
After filling the water tank, can you see if a grey plastic piece, in the back of the water tank, is floating?. If no, then that part needs to be replaced. If it does float, then the integrity of the water sensor, (located in the back of where the water tank is housed into), will need to be tested. Testing this sensor requires, tricking the coffee maker... that the door is closed. With Coffee Maker in the "ON" position, you will need to hold door switch in (located top right corner of unit, with door opened). As switched is held in, you will need to use a magnet and place it around the rear of where the water tank is housed into (Rear-left middle height area)... just around where the water tank float would be, if it were filled with water and inserted into the coffee maker. This sensor isn't visible, but is activated when a magnet is placed around it. If "FILL WATERTANK" message goes away, then replace plastic float or water tank itself.
Top Igia Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Anonymous
Anonymous
Level 1 Expert
Are you an Igia Health and Beauty Expert? Answer questions, earn points and help others
