Computers & Internet Logo
Posted on Aug 06, 2008
Math (5/12)(6/5)with usimg cancellation
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 26, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
313
Points
The 6th term of an A.P is equal to 2.the value of common difference of the A.P which makes the product a1a4a5 least is given by
How fo i cannect 5,12 voot batteries plus breaker to make it 60 volt for my electric scootet
Connecting 12 batteries in series would give slightly more than 61 volts. Considering that under load voltage will drop then it should be ok. Breaker goes between battery and motor on positive wire.
University cancelled required class for graduation?
Talk to the dean of your dept. I had a similar problem and the dean waved the requirements. Good luck
Why is keyboard not powering up at all?
Without the make and model, we'd just be guessing. However, if you're unsure about usimg a multimeter, I'd suggest taking the unit in for repair. You can do more harm than good if you hot the wrong thing.
Feb 21, 2016 • Music
Hdmi port on TV no picture only sound
check resolution setting and try usimg other other knpwn good cable
3helpful
2answers
How do i use external monitor with acer aspire 5516-5474
look for the 9 pin plug similar shape to that on the monitor but female.. check the rear of the laptop (plugs) and match the plug to the socket. The laptop will automatically connect and display once the plug is mated.
Please rate my help++++Thanks for usimg FIXYA
2answers
Intermittantly Prints pages of ascii characters
Check your USB or Parallel cable what you are using. If not solved connect the printer to another pc . Some times computer port may get damage.
2helpful
Sony bravia lcd tv-
If you are using a HD cable box or satelite with component outputs, be sure that all 3 cables ( green, red, and blue ) are making good connection.A loss of red or blue will cause color shift. Usually,if the tv menu comes up as the correct color but the picture dose'nt, it is most likely a signal problem.
Photo stickers
it is possible to print off any amount of items per page and a set amount of rows , but the publishing software you are usimg will determine that in the print options and not the printer itself.
Top SoftMath Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a SoftMath Computer and Internet Expert? Answer questions, earn points and help others
