Denpa USB-24 Digital Voice Recorder Logo
Posted on Apr 12, 2011
Hi, I lost my programs - harbinger converter converter V1.4, please Can you help me?
1 Related Answer
Anonymous
  • 6 Answers
  • Posted on Dec 12, 2007
SOURCE: Harbinger Decoder
Okay, I'll try and help you out...
1. Create new folder on desktop called 'recordings' or something similar i.e. easy to remember!
2. Connect unit to PC via USB cable and turn on the unit. If you slide the HOLD switch to the on position, you should get a message saying "PC LINK" on the display.
3. Locate the recording(s) that you want to decode. I don't know what model of denpa you have, so I can't be sure, but there are normally four folders (A, B, C, and D - there may also be an MP3 folder). The recordings are accessed by double-clicking my computer, then the removable disk icon that appeared when you plugged in and turned on, and then opening the folders that are present which contain the recording(s) you wish to decode.
4. Identify the recording(s) you wish to decode and copy them to your newly created desktop folder (right click the file/copy and then go into new folder and paste there).
5. Once you have copied the file(s) you want to decode, open the Converter program (programs - harbinger converter - converter 1.4).
6. In the program window click on the magnifying glass in the top box (source file) and browse to your new folder.
7. Select the file you wish to decode (I think you have to do them one at a time - just repeat the process for each one following these steps).
8. In the lower box (output file) enter the name you wish to use to identify the file so you can find it. Then click on the magnifying glass for the output file and browse to your newly created folder (this will then be where your converted files will be sent on decoding).
9. Click the 'decode' button in the lower left corner of the program window (I think it shows a picture of two different sized cogs side by side).
10. The file should then be decoded from its .hgl format to a (new) .wav format with whatever name you gave it. From here, you should be able to listen to the file on your PC using any common media player (i.e. Winamp/Media Player etc.) or recode it as an .mp3 if you want to save some hard disk space on your computer.
Repeat the process from step 6 for each file you want to decode.
Hope that helps and good luck.
Top Denpa Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Denpa Audio Player and Recorder Expert? Answer questions, earn points and help others
