Hi, yes sure you can. Just be sure when disassembling to make notes where necessary to keep track of where parts go-and when you get to the lamps ( either under or in back of the meters-use a volt/ohm meter to measure to voltage so you know the size to replace them with ie.. a 6 volt or 12volt. be careful when powering on a disassembled unit ( no parts touching each other, touching a metal part of cabinet) and if you want you can wrap some electricians tape around loose or exposed parts for safety. Good luck, I hope this was of some help and thanks for choosing FixYa. Prodzilla
