SOURCE: Workout difficulty adjusting knob is broken
Remove the cover under it is a rubber wheel and spring and that has worn or the spring has lost the tention replace as needed.
SOURCE: No resistance when I pedal the stationary exercise bike
I looked into this thinking is must be a simple belt, or tention wheel, but these devices are much more complex than the average exercise machine. See the Recumbent selection here.
It appears that the tentioning device is a magnetic brake.
This would require that it be plugged into a power source and programmed to provide a desired tention.
I've never used one of these so I can't say what kind of programming options there are or where they are found.
Hope this helps.
Richard.
SOURCE: magnetic resistance not working on proform gl105
Just oil the area of magnetic resistance and if the problem continues then contact nearer repairer.
SOURCE: proform gr 80 recumbent exercise bike cant get the
The GR80 uses for type D batteries. The battery compartment is on the bottom of the console, look for the D-shaped battery door, press the tab located towards the front side of the console and open the door. Careful, the batteries may fall down if you open the door - type Ds are heavy enough to be felt when they fall on your feet.
