Canon PIXMA iP1200 Photo Printer Logo
Posted on Apr 20, 2011
How do i align my printhead on canon iP1200 - Canon PIXMA iP1200 Photo Printer
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Apr 20, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
12
Questions
Helped
3386
Points
31
I assume you are using windows.
  1. Go to START, SETTINGS, PRINTERS, double click on the printer icon. Go to FILE, to PROPERTIES, then click on the printer SERVICES tab. Click on ALIGN the print cartridge button and follow instructions on the screen. hope this works
  2. Align the print cartridges Typically, you only align print cartridges after installing or replacing a cartridge. However, you may also need to align cartridges when:
    • Characters are improperly formed or are misaligned at the left margin.
    • Vertical, straight lines are wavy.
    From your printer:
    1. Load plain paper.
    2. Press the Menu button, and scroll to Align Cartridges.
    3. Press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
    From your computer:
    2. Open the Canon Pixma IP 1200 Utility.
    3. From the Cartridges tab, click Align Cartridges... . The Cartridge Alignment dialog appears. How do i align my - alignprintcartridgesa.jpg
    4. Click Continue to print the alignment page.
    5. On the Alignment Status dialog, click OK if automatic alignment is successful. If automatic alignment is not successful, clicking OK will return you to Utility Main Window.
Remove and clean printhead on Canon IP1300
To remove and clean the printhead on your Canon IP1300 printer, follow these steps:
  1. Turn off the printer and unplug it from the power outlet.
  2. Open the printer cover and raise the printhead lock lever.
  3. Lift the printhead out of the printer.
  4. Moisten a cotton swab with warm water and gently clean the printhead nozzles. Be sure not to touch the gold-colored electrical contacts.
  5. If the printhead nozzles are heavily clogged, you may need to soak the printhead in a solution of warm water and a mild cleaning agent for a few hours. Be sure to follow the manufacturer's instructions for the cleaning solution.
  6. After cleaning the printhead, shake it gently to remove any excess water, and then let it dry for a few hours.
  7. Once the printhead is dry, replace it in the printer and lower the printhead lock lever.
  8. Close the printer cover and plug the printer back in.
  9. Turn the printer on and perform a printhead alignment to ensure that the printhead is properly aligned.
If you are unable to clean the printhead or if the problem persists after cleaning, it may be necessary to replace the printhead. A new printhead can be purchased from the manufacturer or an authorized dealer.
How to clean print head on canon ip1300
6helpful
Driver canon pixma ip1200
Visit Official drivers and support for Canon Lasershot PIXMA IP1200. Select the Operating System (e.g. Windows XP or Windows 7) and language, click 'submit' to download the required drivers
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
1helpful
HOW TO DOWNLOAD CANON PIXMA IP1200
here http://software.canon-europe.com/products/0010321.asp:
or
here: http://www.findmysoft.com/drivers/download-Canon-PIXMA-iP1200-8-60-printer-driver.html
good luck
3helpful
I have new printhead.
First, go to Canon i9900 Support
If the Support & Service tab is not selected, click on it.
In the search box type reseating printhead and click Search.
One of the results will be "How do I reseat/remove the printhead?"
Click it. A step by step (with animation) will be shown. Just install the new printhead when it calls to reseat the printhead.
Make sure you do the printhead alignment after installing. if you are unsure about how to do this, go back to the support page above and search for align printhead. There will be step by step instructions for this too.
Thanks for using Fixya.
1helpful
Help me please
You Have Requested a Driver.
Here is All the Software listed (At Canon's Website) for the Pixma IP1200.
I Hope This Helps.
3helpful
2answers
Can't find driver to myn canon printer
I need to find driver to my printer: canon pixma IP1200
Grand Canyon Tech
Grand Canyon Tech
Sudeep Chatterjee
Sudeep Chatterjee
