Altusen Aten Maxiport MasterView ACS-1216A (672792151224) KVM Switch Logo
Posted on Apr 21, 2011
We have lost the default password for Aten Master View 1216A KVM Switch Password. How to retreive the same?
5 Related Answers
Anonymous
  • Posted on Feb 17, 2009
SOURCE: Password reset for ATEN kvm switch
If you are unable to perform an Administrator login (because the Username and
Password information has become corrupted, or you have forgotten it, for
example), there is a procedure you can use to clear the login information.
To clear the login information do the following:
1. Power off the CN8000 and remove its housing.
2. Use a jumper cap to short the jumper on the mainboard labeled J6.
3. Power on the switch.
4. When the front panel LEDs flash, power off the switch.
5. Remove the jumper cap from J6.
6. Close the housing and power on the CN8000.
After you start back up, you can use the default Username and Password (Login: administrator, pass: password).
Anonymous
  • 526 Answers
  • Posted on Aug 15, 2009
SOURCE: Lost the instructions for the CS62U switch
here is the link to the aten website.
http://www.aten.com/download/download.php#productGuide
go to the select quick guide section and locate the model # in there,
p.s. its cs not c5
Anonymous
  • 2777 Answers
  • Posted on Nov 05, 2010
SOURCE: My Altusen Aten CS62U-2 Port USB KVM Switch seems
It very well could be just a cable causing this problem, try switching around the cables to see if you can isolate the issue. It could be the KVM is not compatible with your monitors refresh rate though, I have seen this happen a good number of times. It will work but will blink randomly to allow the monitor to re-sync with the video card.. . I have a monitor currently on a kvm that does this exact thing. You may want to try another KVM if you can't get it narrowed down to certain cables.. there is a chance the actual KVM is causing this issue, but is not defective, it is just at a different frequency then the monitor.
Thanks so much
Tim
Anonymous
  • 14 Answers
  • Posted on Jan 05, 2011
SOURCE: I have an Aten CS62US
Reading a manual would be more useful, and if not please find out how to do configure the hot keys of a kvm switch at kvmstuff.com.
Anonymous
  • 14 Answers
  • Posted on Jan 11, 2011
SOURCE: I have Aten USB KVM
You can check out here- there's a lot many Aten usb kvm switch, check your model and find out how to resolve your problem http://www.kvmstuff.com/server-management/kvm-switches/usb-kvm-switch.html
Top Altusen Computers & Internet Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Altusen Computer and Internet Expert? Answer questions, earn points and help others
