Buffalo Technology 320GB MINISTATION TURBO USB 2.0 5400 RPM PORTABLE HDD Hard Drive Logo
Anonymous Posted on Apr 23, 2011
I have a problem that when i link the hdd with my computer it works fine then i go into it and try to open the file but its a shortcut and it opens the file in a different window and it opens up internet explorer for some reason, and also i'm pretty sure the problem is the 0xFFD12566 thing because it keeps coming up on my anti-virus program and says its been successfully, help is very appreciated.
Brian Sullivan
Level 3:
  • Buffalo Tech... Master 27,725 Answers
  • Posted on Apr 23, 2011
Brian Sullivan
Level 3:
Answers
27725
Questions
Helped
5776703
Points
79191
I think there might be a conflict
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
  • Brian Sullivan
    Brian Sullivan Apr 23, 2011
    you could run the chkdsk utility
    click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage your computer
    hope this helps
Top Buffalo Technology Computers & Internet Experts
Sudeep Chatterjee
Sudeep Chatterjee
Grand Canyon Tech
Grand Canyon Tech
woodzowl307
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
