SOURCE: whirlpool wm 1000 semi pro washing machine
if you can give a more complete mod # i can help you on the front loaders its a slow drain time the mod # you gave me dont come up look on the lid or the back of the control panel for ser plate http://www.whirlpool.com/custserv/index.jsp try here for manual
SOURCE: error code 43 on F& P washing machine
The micro switch or the lever that activates it seems to have been the cause of the Error Code 43. Have re-seated the switch in its holder and ensured the activating (out of balance) lever is moving freely. The switch appears to be OK and now it is all re-assembled, the Error Code 43 is gone. Machine is operating normally again.
Out of Balance Switch was located below the right hand side of the computer board (module).
Rgdz John T
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
SOURCE: We are getting error code E3. What does this mean
Looks like you have either a stuck drum (does not spin) or an electrical fault that make the washer think the drum is not moving.
From a 2006 Technical Bulletin:
E3: Machine control is attempting to drive the motor but is not seeing any tach response. Visual Check shows motor is not moving. (Locked or Hall Sensor fault.)
Specifically, it could be:
1. Spin drum stuck – Verify that the spinner moves freely to eliminate this cause.
2. Hall Sensor (integral part of motor) fails or is loose – When the Hall Sensor fails or becomes dislodged, the control doesn't recognize that the motor is spinning and shuts down. The result will likely be an “E3” code in the worst case, or “SUdS” if it is only getting a partial rpm reading. Check wire harness connector(s) to motor.
Unless you are really overloading your machine you likely have an electrical fault, or a failure in the drive train--especially if the problem is intermittent. Probably time to call in a technician.
SOURCE: code f23 for whirlpool washing machine
It means that there is a fault in the heating circuit and the heater is not working
The listed site deals with this problem so take a look and if you are fully capable of testing, follow the troubleshooting instructions but always double check that the unit is unplugged or disconnected from the electrical supply.
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
And remember kindergarten rule #1 "If in doubt, don't" with everything that is potentially dangerous. Electricity kills so a service repair bill may be a better solution.
Hope this helps.
jenni.
