Computers & Internet Logo
Anonymous Posted on May 09, 2011
I had a problem with flashdisk. Flashdisk can not be in the format, if we want to format it will display the message "The disk is write protected". How do I fix this? Thank you
Anonymous
Level 2:
New Friend:
  • Expert 115 Answers
  • Posted on May 09, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
115
Questions
0
Helped
17270
Points
338
Maybe your computer user account has a limited access. Check the user account you are using. This must be in full access control. After doing it try to format again the disk. Return to me if the problem still exisit after doing it.
  • Anonymous May 09, 2011
    Hi. I made a procedure for you. Just follow it.
    1. go to start menu
    2. click run then type regedit
    3. then a window will pop up
    4. look for HKEY_LOCAL_MACHINE then click it to expand
    5. then right click to the SOFTWARE then click PERMISSION
    6. then another window will pop up
    7. then click the user that you are using
    8. then check all the boxes in the full control
    9. then click APPLY
    10. then click OK
    11. Try to format again your disk
  • Fury Fury Rior
    Fury Fury Rior May 27, 2011
    Try WinSetupFromUSB, and just try format from this software
    or just contact me at var90vr@yahoo.com
    i will help u...
    Thx
Unformat floppydisk emulator
Floppy emulator can't read flashdisk untill it formatted.
Flashdisk MUST BE format by special softwares.
Install the softwares on the PC/notebook.
No matter how much flashdisk capacity,floppy emulator will continue to read as one 1.44MB floppy.
Through special softwares formater, we can determine how many floppy that we will create. Lets say,100 floppy (or more),softwares will format the floppy 1.44 100 times on the flashdisk.
So we have 100 pieces 1.44MB floppy inside flashdisk. If one floppy can store about 30 MIDI songs,then it means that we already have 3000 songs in flashdisk.
If you format for 100 floppy,the total capacity of about 144MB.
So,flashdisk with a 2GB capacity, is more than enough to store songs.
To change from one floppy to enother,just press bank number at floppy emulator panel.
I hope this helps.
Regards.
Why my san disk usb fash when i check its properties shows only 8mb out of 2gb and doesnt allow to be formatted
Whenever a computer tries to access a flashdisk, even for just retrieving the properties of the disk, a LED will flash.
Not being able to format your disk is another thing. If you've opened a file at this disk, Windows will prevent formatting. Best is to restart your PC, and than immediatelly start the formatting-process.
400gb sony flashdisk copying error
you try it again after restart.
I have usb flashdisk 8 GB, but I can't format because of write protected
Go into the properties tag on the Flash drive and unset the Write Protected box.
I have lock my Kingston from imation lock.
you can try formatting it from the disk manager.
plug in the flash drive and remember what drive letter it gets assigned. right-click 'my computer' and choose manage from the drop-down menu. in the following window, click on disk management (under storage) on the left, then right-click on the flash drive and choose format...
I had problem with imation lock
how format flash imation 8 gb write protected
1helpful
To unprotect
It would depend on your Operating System. If you are using Windows 98 you'll need the drivers from your CD or from Apacer's website. The CD also has tools to perform various functions which might include protecting and unprotecting your flash disk.
Apacer's download site: http://usa.apacer.com/us/support/downloads.asp
1helpful
2answers
Cannot formating
ok, you have hard drive and then you have flash disk.
I assume you are talking about a memory stick flash drive.
is this for you computer or camera?
If you are talking about a memory stick/flash drive for your computer it is not necessary to format it for it to be usable.
Hope this helps
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
