It probably doesn't matter about finding a replacement grid since Sharper Image recalled the units after losing a lawsuit with Consumer Reports because they couldn't prove they clean the air. They had to pay all legal fees forcing the company into chapter 11.
Consumer Products Safety Commission is going to release a report on all ionizers. Their decision could affect the sales of any ionizers in the U.S. Even EPA data shows that not only do they not work but there harmful to use.
It will attract dust, and collect it, but in order for an air filtering system to work, air has to pass through it. The Ionic Breeze has no fan system to move air, so it relies on normal room air currents to push air through it.
Try cleaning the collection grid. If that doesn't work, try blowing out the dust inside the unit. (Air compressor if you have it would be helpfull.) Otherwise you may have to just buy another grid. Not that many online try ebay.
hi,
Sparking, popping, hissing or crackling sounds coming from your Ionic Breeze air cleaner are all signals that it's time to clean your machine. Once you've cleaned the collection grids inside the Quadra, the disruptive sounds will disappear
how to clean
Turn off and unplug your Ionic Breeze Quadra.Grasp the horizontal handle on top of the air cleaning grids--this is in the very center top of your Ionic Breeze Quadra--and pull the grids straight up out of the casingWipe the metal grids down, inside and out along the entire length, with a clean damp cloth. You may need to use more than one cloth if the grids are very dirty.Go back over the grids with a clean dry cloth to remove any water and remaining dirtPut the grids aside on a clean, dry surface and grasp the body of the main Ionic Breeze casing unit in both hands.Flip the casing unit upside down, then right side up, five or six times. You should hear a small bead sliding back and forth as you do this. The bead is cleaning interior elements concealed in the casing; if you don't hear it, your unit may be in need of repair.Place the casing unit back on its base, orient the grids so that the handle slopes in the same direction as the top of the air purifier, then carefully slide them back down into the machine.
Well there is a small micro switch that is actuated by the grid. This is mounted on the side of the top control piece. There are two wires attached to the little circuit board, usually one is corroded so you need to cut it back and soder it to the center pin of the switch. also check the fuse.
Replacement grids have been posted to ebay. You can replace the complete unit for $45 on ebay so that would probably be a better solution. The last grid I purchased on ebay for similar was around $20.
I have been doing research on this unit. I read that only every other grill is suppose to collect. The remaining grills increase the electrostatic charge making the collection plates, the ones that get dirty more effective. So the bottom line is there is nothing wrong with your unit.
I had the same problem and could not find an answer anywhere. So here's what I figured out. The small wires running from top to bottom just inside the cover are your problem. Not the metal grid with plates that you can remove. The buzzing sound you heard is the resistance one or more of the wires is causing. The resisitance tells the pc board that your grid must be wet and therefore the unit goes into drying mode. I replaced my small wires and my unit is working better than ever. The wire is .005 diameter( important so that you keep the same resistance flowing to the pc board) and can be purchased at any good suppy house. I have since repaired another unit with an even simplier fix. I took the unit into a dark room and then turned it on. Watching the grid I could see the wire arching that was causing the resistance. Unplugged the unit, turned it over and with a flat head screw driver pushed the wire off its base connedtion. Turned the unit right side up and removed the wire from its top support. The unit works fine without the troubled wire. Hope this helps.
