LG WM2487H Front Load Washer Logo
Posted on May 16, 2011
What does the error code UE mean on an LG wm14225 washing machine?
Anonymous
Level 1:
New Friend:
  • Contributor 14 Answers
  • Posted on May 16, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
14
Questions
0
Helped
2958
Points
48
UE indicates an unbalanced load
2helpful
LG top load washer has a 'UE' Error.
Question edited for clarity
An LG washer displaying the UE or uE error code means that the load in the washer is unbalanced. ... When the uE error code is displayed, it means that the washer is trying to resolve the issue. The washer will fill with water to try to balance the load. It will then drain and try to spin again.
Jun 7, 2021
How to Fix the LG Washer UE Error Code - Fleet Appliance
https://fleetappliance.com > News and Tips
2helpful
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
What Does the error code UE (U3)? mean?
Hello..
UE means Unbalance Error.. Check your machine legs and ground level properly.. And the main think is dont put a single blanket.
I have a LG TROMM WM2277HS front load washing machine. Error code UE displays when there is 3-5 minutes left in the cycle. I have tried rearranging the load, making it lighter or heavier. I have also ran...
Hi.. UE error means unbalance error..Check your floor level and machine legs... after u checking ur floor level and legs also perfect means change the suspension rod.
17helpful
LG front load washer coded UE. what does that mean?
UE means unbalanced error. when you see this, it means the clothes are unevenly distributed in washer, it's basically unbalanced.
4helpful
Error code UE on LG F1247 TD5 washing machine
it means uneven load do u have a pillow in there or something that soaks up lots of water!!
2helpful
5helpful
LG WM 14316FD washing machine
An UE Error Code is indicative of a “Unbalanced Error”. This indicates that the drum is not spinning in a smooth rotation. It may be necessary to rearrange the load in the drum. I found this answer on the lg web site.
33helpful
7answers
Ue error code on the display
For "ue" an unbalanced load is sensed three times, re-adjust your load in the machine.
For e1, it could be a water sensor problem. Check to see if the inlet valve is okay and not clogged, water shd be in good pressure. If this is okay, open up behind after taking the plug off the wall. There is a thin tube coming from the switch area to the outlet pump area; disconnect this from the top carefully and blow into it, it should be free; if it is clogged you will hav a water level problem. Unblock and refit carefully.
Top LG Washing Machines Experts
Sudeep Chatterjee
Sudeep Chatterjee
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
