SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
SOURCE: I have a John Deere 116 not getting gas to the filter or carb
Fuel line is pinched between fuel tank and frame.You should see the line coming down the rear side of tank,grab it and see if its free to move.
SOURCE: We have a 3020 john deere gas we just had head
A couple of things should be looked at.
1. Make sure head gasket is aligned properly and not blocking any ports on the head or block. 2. When the head was milled debris may have been pushed into a port blocking flow, check for blockage. 3. When you replaced the head, did you torque the bolts in the proper sequence and to the specified ft/lbs?
You might go ahead and put a manual oil gauge in place of your oil sending unit..back side of eng block r/h side.. check you pressure,needs to be between 15 to 25 psi at low ideal,with the eng at at operating temp.The head oils from the back main to the back camshaft bearing to a port at the R/H back part of the eng block to the head.Go ahead and pour some oil on the rocker arm assemble and let the tractor run a bit work it up to high ideal.If it doesnts oil possible problem with the head gasket being ported wrong are back cam bearing,
Hi Unhook
the fuel pump feed to carb line and place it over a gas can with ignition
disabled to see if it is pumping any fuel at all. If you are getting fuel past
the filter and pump (should be low pressure) your next bet would be to check
the carb itself. Many smaller motors that aren't run often can develop deposits
or contaminants that clog small ports or jets in the carb and prevent fuel from
making its way into the motor. If you have any available you may want to try
spraying a little starting fluid into the carbs while cranking to see if it
will help it turn over. However
if you are getting gas out of the bowl, then it can't be a plugged fuel filter.
It could be bad needle-valve or blocked passage. Take the carb apart and soak
it overnight in Lacquer thinner then blow it out with an air compressor. The
float should be set slightly higher than level with the carburetor upside down. Also
check this helpful link to troubleshoot your issue:- http://www.lawnmowerman.tv/Troubleshooting.asp Please
get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
