SOURCE: programming
push the tv button then hold down the code search button till the light becomes solid. point the remote at your tv while it is turned on and push the channel up or down til the cannel changes. once it does push the mute key to save. so u know this works like that on all device and if you pass up the right on from pushing the button too fast you can just push the opposit direction rather than waiting for full circle. also be aware that there are multiple codes for some devices and some work better than others.
SOURCE: zenith zn620 universal remote
In case anyone ends up seeing this in the future, there is an alternate way of programing devices with the Zenith Universal Remote other than just direct code entry.
It's a sort of automatic searcher, and the process goes like this:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device to be controlled changes
channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
SOURCE: lost the remote code book for Rca universal remote
codes are 1054, 1133, 1155, 1161, 1162, 1166, 1176
SOURCE: Can't auto program Zenith TV for cable channels
