SOURCE: x2000+: no thermal transfer options and Argobar Pro issues
netsrapcc:
I don't have an Arox printer or Argobar, but I've seen similar messages from other programs.
First, I'd open a file in Argobar and make sure that another printer has not been selected. If the printer name has changed since the file was saved, the program probably selected your default printer, with far different attributes (higher resolution, different fonts, no thermal options).
Also check the printers properties (probably under an "advanced" option) to make sure the driver is installed for the correct model. If your printer supports label sensing other than "Media with Gap", the driver should show other settings. If a label is fed consistantly to the same spot when you Form Feed, then your sensor is working. It might take two From Feeds - one to advance the leading eadge to the printhead and one to advance the trailing edge to the tear bar.
If you just installed XP SP3, you might need to re-install the driver. You can download from Argox, but I prefer Seagull drivers, at http://www.seagullscientific.com/aspx/thermal_printer_list.aspx#Argox . There are several +2000 models listed. These work with XP SP3. You should be able to set many attributes in the Proerties and Preferences.
Occasionally, one or two files may be saved incorrectly and become corrupted (but never ALL files). In these cases, it easier to start a new file, with the proper label size, and copy & paste (if your software lets you) from the old to the new. Once I get files working well, I always copy them to a another folder.
By the way, if you have already printed with Direct Thermal settings, but had a ribbon loaded, the print head has not been damaged. Direct Thermal should turn off the warning when the ribbon sensor doesn't find a ribbon, and probably changes some of the heat attributes to optimize for ribbonless printing, so the quality with a ribbon is decreased.
The printhead can be gently cleaned occasionally with 70% Isopropal Alchohol on a Qtip, but never touch the printhead with a hard object. One tap with a metal object while the printer is on would probably destroy that part of the printhead.
I hope this helps!
God bless,
Label Guy
SOURCE: My printer page is like 1/2 i.e. 1 row has 2 print
It is a problem with printer logic card. so you can checked it from service center.
SOURCE: feeding
Hello Sarunas,The problem ultimately, might lie with label feeding,Try Printer feeding,when u give the feed button, the labels should automatically, stop at the gap position, try printer calibration settings.
Hope fully, this should solve your problem
If you Any other queries,
Related to barcode printer - Sales and Services.
Contact , Trridev Labelss Mfg Co
Leading Labels Convertors In Tamil nadu
For more information visit our web page.
SOURCE: I have godex 1100 barcode
You did not tell us, whether it is not printing barcode's alone or no text is printing.
You might hear beeps for 2 reasons,
Sensor posistion is not correct.
or ribbon is not correctly fitted.
Kindly check both these.
hope this will solve your problems.
If you have any other queries with barcode printer
kindly mail/call us.
Regards
Web Marketing Division
www.trridevlabelss.com
email Kirubakaran.rv@gmail.com
trridevlabelss@gmail.com
Manufactures of Self adhesive labels
and resellers of barcode printers and scanners and ribbons
