SOURCE: How do i cut my shimano xtr hydraulic hoses to size?
You need spare olives (the brass ones are best) buy on Chainreactioncycles.com, measure your hose and allow for bad cut first time so add a Cm to measurement you can cut away just make sure that you use really sharp cutter (I use craftknife) place hose on non slip surface and cut cleanly, push on olive and reattach and tighten
SOURCE: replace cable on shimano sl m510 shifter
Official drivetrain instructions from the manufacturer:
http://techdocs.shimano.com/media/techdocs/content/cycle/SI/Deore/RearDriveSystem/SI-R740G-En_v1_m56577569830612825.pdf
Look at the picture under Installation of the Lever.
SOURCE: Describe your shimano xtr rear derailleur spare
Broken inner plate can be a potential warranty. Contact your local bike shop and they can process the warranty for you, if it isn't a warranty then the same shop can order you a new plate.
SOURCE: I just bought a TREK bike with SHIMANO
With a bike this old the best thing is too take the bike into your local bike shop and have them give it a once over to look for any potential problems. THIS IS A FREE SERVICE ALL SHOPS OFFER.
The problem specific could be as simple as the cable is very loose and not engaging the cable, or the cable could be so old that it is frozen inside the housing and nothing is happening. It could also be that the cable is broken, the shifter is broken or something other. It is impossible to diagnosis this particular problem with certainty without actually seeing and feeling the issue.
Bottom Line: Take it into a shop and get a mechanic to look at it.
