Televison & Video Logo
Posted on Jun 20, 2011
It has been a week since we installed two new mlr 750 a week later none of the transmitters work unless u get up so close your practicaly touching the motor deleted all codes and re programmed still not working. help!!!!!
5 Related Answers
Anonymous
  • 98 Answers
  • Posted on Feb 07, 2009
SOURCE: remote/homelink and touchpad problem
Your keypad is not the same "generation" as your remotes. You operator will work with your security plus remotes or your old keypad but not both. Yor cheapest solution is to replace your keypad.
Anonymous
  • 3197 Answers
  • Posted on Sep 16, 2009
SOURCE: Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Testimonial: "Thank you. So does that mean I have to replace my receiver?"
Anonymous
  • Posted on May 05, 2010
SOURCE: TOUCH PAD ISN'T WORKING, CURSOR WON'T MOVE
your touchpad might have a 'lock' button nearby it, to enable or disable its sensitivity. this is usually helpful while typing, so you can disable it so that the when the touchpad gets touched, the mouse won't make any reaction. You can then enable it to work with the mouse. This button is usually either near the top border or near one of the four borders. Alternately, some laptops have a function key for touchpad enable-diable thing. It is usually Fn + F3. The function key (Fn) is near the Ctrl key. The touchpad key, in the in colour of the Fn key will be somewhere in the Function keys.
swolfinor
STEVE WOLFINBARGER
  • 504 Answers
  • Posted on May 23, 2010
SOURCE: unable to program remotes from opener
TRY UNPLUGING THE UNIT WAIT ABOUT 5 MIN. PLUG IT BACK IN CLEAR THE CODES BY HODING DOWN THE PROGRAM BUTTON FOR ABOUT 20 SECONDS.
NOW YOU ARE READY TO PROGRAM A REMOTE TO THE SYSTEM.
HOPE THIS HELPS
Anonymous
  • 3197 Answers
  • Posted on Nov 29, 2010
SOURCE: I have a Sears (Chamberlain)
Make sure you are using the correct procedure to program the keypad.
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Top Chamberlain Televison & Video Experts
Arnie Burke
Arnie Burke
Anonymous
Level 1 Expert
Anonymous
Level 1 Expert
Are you a Chamberlain Televison and Video Expert? Answer questions, earn points and help others
