LG LWD3081ST Electric Double Oven Logo
Posted on Jun 22, 2011
F19 error code on lg double oven - LG LWD3081ST Electric Double Oven
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Dec 27, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
15974
Points
Had F19 error code on lower oven, F9 on upper. Pulled stove out and turned the regulator switch ON. Worked instantly. I thought I had the regulator on because the stovetop worked. The stovetop regulator is separate from the main regulator!!
2 Related Answers
Anonymous
  • 527 Answers
  • Posted on May 15, 2009
SOURCE: F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
Anonymous
  • Posted on Sep 25, 2010
SOURCE: kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Top LG Ovens Experts
vince
Paul Carew
Are you a LG Oven Expert? Answer questions, earn points and help others
