This error code indicates that drain times are longer than expected.
Click the following to learn more about proper drain systems for BravosTM washers. The example shown is for an impeller washer but is applicable to washers with agitators.
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the
hose for adequate water flow. Remove any blockage from the drain hose,
drainpipe or utility sink. Use the U-shaped drain hose form on the drain
hose, and secure the drain hose. See the Installation Instructions for
details.
Is the end of the drain hose more than 96" (244 cm) above the floor?
The drainpipe (standpipe) height requirements are: 96" (244 cm)
maximum and 39" (99 cm) minimum. Your washer will not be able to
adequately pump the water out of the washer if the drainpipe (standpipe)
exceeds 96" (244 cm). In this case, the water may flow back into the
washer. See the Installation Instructions for details
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
NOTE: If the error remains on the display, and both of the questions above have been checked, call for service.
Hope this helps.
