SOURCE: Camera Won't Stay On.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes....
thank u
rate me
SOURCE: my kodak easy share M1063 turns on then shuts right off how do i
I had the same exact problem. When the camera turns on and then lens extends, hold the lens out while the camera shuts off. Then sort of move it around a bit. I did this and when I turned it on, it was fixed. I guess something was jammed in the lens.
SOURCE: My Kodak EasyShare M340 turns on, but then shuts off immediately.
omg! thank you so much Stephan you are th best i just bought the camera for Christmas. Went to the beach yesterday and it sttopped working the method with holding the lens and moving it around i saw some sand come out now it works!!!!!! :-D
SOURCE: I will be traveling to Egypt in a month with a
In Egypt, they are using 220 V; Plug C. If your charger is using 220 V then you don't need to bring anything. You will need a voltage converter and plug adapter in order to use 110V chargers.
